1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cisco Serial Console Rollover Adapter (M/F) RJ45 to RJ45, Shielded, Blue
MODEL NUMBER: N034-001-SH
Highlights
Connects to any standard RJ45
patch cable to create a rollover
connection
Internally rolls the pins to
convert straight-through cable to
rollover cable
Color-coded blue for fast, easy
identification in a crowded
switch or router
Recommended for Cisco
modems, routers, switches and
other serial devices
Applications
Converts a standard Ethernet cable into a serial rollover cable for connecting to Cisco or other hardware
that requires rolled cables.
Connect devices like Cisco
switches, routers or other
hardware that require rolled
cables to an Ethernet network
Change ports on a network
device from straight-through to
Cisco rollover
System Requirements
Cisco or other network hardware
using RJ45 serial ports that
Standard Ethernet patch cable
with RJ45 connectors
Features
Rollover Console Adapter Converts a Straight-Through Ethernet Cable to a Rollover CableThis
Cisco serial console rollover adapter connects to the end of any standard RJ45 Ethernet cable and
internally rolls the pins to convert the cable from straight through to rollover. This allows you to create a
rollover connection between a computer terminal and the RJ45 console port on a Cisco modem, router,
firewall, switch or other serial-based device without having to buy new cabling.
Package Includes
Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis Cisco console rollover
adapter features blue PVC molding. The color-coding allows easy, fast identification in a crowded switch
or router and helps prevent the cable from becoming inadvertently disconnected.
Specifications
OVERVIEW
UPC Code
037332253064
Technology
Cat5/5e; Cat6
PHYSICAL
Color
Blue
Cable Jacket Material
PVC
Cable Shielding
STP
Unit Dimensions (hwd / in.)
0.740 x 0.810 x 2.070
Unit Dimensions (hwd / cm)
1.88 x 2.05 x 5.25
1/2
N034-001-SH Cisco Console
Rollover Cable Adapter (M/F) RJ45 to RJ45, Shielded, Blue
Cleveland, OH 44122
United States
Unit Dimensions (hwd / mm)
18.8 x 20.5 x 52.5
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Relative Humidity
0% ~ 90%, Non-Condensing
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (FEMALE)
STANDARDS & COMPLIANCE
Product Compliance
RoHS
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N034-001-SH”相匹配的价格&库存,您可以联系我们找货
