N042AB-004-IVM
N042AB-004-IVM
    TRIPPLITE
    4 端口 面板 乳白 单组
N042AB-004-IVM 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Safe-IT 4-Port Single-Gang Keystone Wall Plate, Antibacterial, Ivory Matte, TAA MODEL NUMBER: N042AB-004-IVM Highlights ● Ideal for home theater, VoIP or Ethernet in-wall wiring installations ● Made with antibacterial material proven effective in inhibiting E. coli and staph ● Compatible with all keystone jack types, including HDMI, Cat5/6, USB and DisplayPort ● High-impact plastic construction designed to blend in with your home/office décor ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes Clean, simple faceplate with keystone jack ports mounts to a wall for terminating premise audio/video, voice or data cable applications. Features 4-Port Wall Plate Connects Your In-Wall Audio/Video, Voice or Data Cable Lines This single-gang wall plate provides a clean, simple method for terminating your premise wiring applications, including home theater (audio/video), VoIP phones (voice) and Ethernet (data). Any type of keystone jack, including those used in HDMI, Cat5/6, USB and DisplayPort installations, snaps easily into the cutouts for quick cable connection. Provides Extra Protection Against Certain Bacteria The wall plate is constructed using an antibacterial material that is effective in inhibiting Escherichia coli (E. coli) and Staphylococcus aureus (staph) and tested to ISO 22196:2011 standards. This added protection makes this cover plate an ideal solution for medical facilities, schools, businesses, restaurants/kitchens and anywhere else that needs extra protection against bacteria. High-Impact Construction Designed to Blend In Seamlessly with Your Room This durable faceplate with an ivory matte finish blends elegantly into any home or office décor for a sleek, professional installation. Mounting screws are included. The ABS plastic construction meets UL 94V-0 flame-retardant standards for protection against fire and high heat. TAA-Compliant for GSA Schedule Purchases The N042AB-004-IVM is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332269126 Accessory Type Wall Plate Technology Cat5/5e; Cat6; Cat6a; DisplayPort; HDBaseT; HDMI; USB 2.0 (High Speed) 1/2 ● N042AB-004-IVM 4-Port SingleGang Antibacterial Keystone Wall Plate, Ivory Matte ● (2) Mounting screws 1000 Eaton Boulevard Cleveland, OH 44122 United States Country/Region Global PHYSICAL Color Ivory Material of Construction ABS (ABS-764) Total Number of Ports 4 Unit Dimensions (hwd / in.) 7.680 x 5.000 x 0.500 Finish Matte ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -40° to 154°F (-40° to 68°C) Operating Humidity Range 10% to 90% RH, (Non-Condensing) Storage Humidity Range 10% to 90% RH, (Non-Condensing) CONNECTIONS Number of Ports 4 Side A - Connector 1 (4) KEYSTONE JACK CUTOUT FEATURES & SPECIFICATIONS Antibacterial Yes STANDARDS & COMPLIANCE Product Certifications CSA (Canada); UL 94; UL Listed; cUL Listed Product Compliance RoHS; REACH; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N042AB-004-IVM
1. 物料型号:N042AB-004-IVM 2. 器件简介:这款墙板适用于家庭影院、VoIP或以太网墙内布线安装,由抗菌材料制成,可有效抑制大肠杆菌和金黄色葡萄球菌。 3. 引脚分配:包含4个端口,每个端口都有钥匙孔插座切口,适用于HDMI、Cat5/6、USB和DisplayPort等类型的钥匙孔插座。 4. 参数特性: - 技术:支持Cat5/5e、Cat6、Cat6a、Display Port、HDBaseT、HDMI、USB2.0高速 - 颜色:象牙色 - 材质:ABS (ABS-764) - 尺寸:7.68 x 5.00 x 0.50 英寸 - 表面处理:哑光 - 工作温度范围:14°F至140°F(-10°C至60°C) - 存储温度范围:-40°F至154°F(-40°C至68°C) - 工作湿度范围:10%至90%RH(非凝结) - 存储湿度范围:10%至90%RH(非凝结) 5. 功能详解:提供一种干净、简单的方法来终止您的布线应用,包括家庭影院(音/视频)、VoIP电话(语音)和以太网(数据)。 6. 应用信息:适用于医疗设施、学校、企业、餐馆/厨房等需要额外抗菌保护的地方。 7. 封装信息:ABS塑料结构,符合UL 94V-0阻燃标准,以防火和高温。 8. 合规性:符合联邦贸易协定法案(TAA),适用于GSA(总务管理局)计划和其他联邦采购合同。 9. 保修与支持:提供全球范围内的终身有限保修。
N042AB-004-IVM 价格&库存
很抱歉,暂时无法提供与“N042AB-004-IVM”相匹配的价格&库存,您可以联系我们找货
