N042E-WF1
N042E-WF1
    TRIPPLITE
    无,开放式中心 端口 模块插件 白色 单组
N042E-WF1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Single-Gang European-Style Gang Frame for Insert Modules, White MODEL NUMBER: N042E-WF1 Highlights ● Ideal for home theater, VoIP or Ethernet in-wall wiring installations ● Helps prevent accidental cable damage and hides unattractive wiring ● Compatible with N042E-Series European modules and inserts ● High-impact plastic construction designed to blend in with your home/office décor Package Includes N042E-WF1 Single-Gang EuropeStyle Gang Frame, White European-style gang frame accepts compatible inserts for terminating premise audio/video, voice or data applications. Features European Gang Frame Connects Your In-Wall Audio/Video, Voice or Data Cable Line This European-style outlet gang frame for mounting and trunking is ideal for terminating your premise wiring applications, including home theater, VoIP phones and Ethernet. The N042E-WF1 protects electrical and network cables to help prevent accidental damage to your application. It’s compatible with N042E-Series European unloaded modules and blank insert (sold separately). High-Impact Construction Designed to Blend In Seamlessly with Your Room This white plastic cover plate measures 81 x 81 x 15 millimeters (outer frame) and 45 x 45 millimeters (inner frame). It helps hide unattractive cabling and blends elegantly into any home or office décor for a sleek, professional installation. The ABS plastic construction meets UL 94V-0 flame-retardant standards for protection against fire and high heat. Specifications OVERVIEW UPC Code 037332268853 Accessory Type Wall Plate Technology Cat5/5e; Cat6; Cat6a; DisplayPort; HDBaseT; HDMI; USB 2.0 (High Speed) Country/Region Europe PHYSICAL Color White Material of Construction ABS 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Total Number of Ports 0 Unit Dimensions (hwd / in.) 1.770 x 1.770 x 0.590 Finish Matte ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -40° to 154°F (-40° to 68°C) Operating Humidity Range 10% to 90% RH, (Non-Condensing) Storage Humidity Range 10% to 90% RH, (Non-Condensing) FEATURES & SPECIFICATIONS Antibacterial No Snagless Connector No STANDARDS & COMPLIANCE Product Certifications UL 94; UL Listed; cUL Listed Product Compliance RoHS; REACH; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N042E-WF1 价格&库存
很抱歉,暂时无法提供与“N042E-WF1”相匹配的价格&库存,您可以联系我们找货
