N042E-WHM-C1
N042E-WHM-C1
    TRIPPLITE
    连接器 空面板 白色
N042E-WHM-C1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1-Port European-Style Insert, Coax Coupler (F/F), 22.5 x 45 mm, White MODEL NUMBER: N042E-WHM-C1 Highlights ● Ideal for home theater or VoIP phone in-wall wiring installations ● High-impact plastic construction designed to blend in with your home/office décor ● White insert measures 22.5 x 45 mm for a sleek, professional appearance Package Includes N042E-WHM-C1 1-Port EuropeStyle Insert, White European-style module accepts a compatible coaxial cable for terminating premise audio/video, voice or data applications. Features European Module Connects Your Coaxial Audio/Video, Voice or Data Network This European-style insert with coax cable connector (F/F) is ideal for your premise wiring applications, including home theater, telephones or radio communications. The insert is compatible with N042E-WF1 wall plate. High-Impact Construction Designed to Blend In Seamlessly with Your Room This white module measures 22.5 x 45 millimeters and blends elegantly into any home or office décor for a sleek, professional installation. The ABS plastic construction meets UL 94V-0 flame-retardant standards for protection against fire and high heat. Specifications OVERVIEW UPC Code 037332268938 Technology Cat5/5e; Cat6; Cat6a; DisplayPort; HDBaseT; HDMI; USB 2.0 (High Speed) Country/Region Europe PHYSICAL Color White Material of Construction Brass Total Number of Ports 1 Unit Dimensions (hwd / in.) 1.772 x 0.886 x 0.335 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Finish Matte ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -40° to 154°F (-40° to 68°C) Operating Humidity Range 10% to 90% RH, (Non-Condensing) Storage Humidity Range 10% to 90% RH, (Non-Condensing) CONNECTIONS Number of Ports 1 Side A - Connector 1 KEYSTONE JACK CUTOUT FEATURES & SPECIFICATIONS Antibacterial No STANDARDS & COMPLIANCE Product Certifications UL 94; UL Listed; cUL Listed Product Compliance RoHS; REACH; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N042E-WHM-C1 价格&库存
很抱歉,暂时无法提供与“N042E-WHM-C1”相匹配的价格&库存,您可以联系我们找货
