N042F-WF2
N042F-WF2
    TRIPPLITE
    无,开放式中心 端口 面板 白色 双组合
N042F-WF2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Double-Gang French-Style Gang Frame, White, TAA MODEL NUMBER: N042F-WF2 Highlights ● Ideal for home theater, VoIP or Ethernet in-wall wiring installations ● Helps prevent accidental cable damage and hides unattractive wiring ● Compatible with select N042ESeries modules and inserts (sold separately) ● High-impact plastic construction designed to blend in with your home/office décor ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes N042F-WF2 Double-Gang FrenchStyle Gang Frame, White, TAA French-style gang frame accepts compatible wall-mount inserts for terminating premise audio/video, voice or data applications. Features French Gang Frame Connects Your In-Wall Audio/Video, Voice or Data Cable Line This gang frame for mounting or trunking is ideal for terminating your premise wiring applications, including home theater, VoIP phones and Ethernet. The French-style N042F-WF2 protects electrical and network cables to help prevent accidental damage to your application. It’s compatible with N042E-WM1-S unloaded shuttered module and N042E-WHM0 blank insert (sold separately). High-Impact Construction Designed to Blend In Seamlessly with Your Room This white cover plate measures 80 x 130 millimeters (outer frame) and fits two 45 x 45 millimeter modules. It helps hide unattractive cabling and blends elegantly into any home or office décor for a sleek, professional installation. The ABS plastic construction meets UL 94V-0 flame-retardant standards for protection against fire and high heat. TAA-Compliant for GSA Schedule Purchases The N042F-WF2 is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332268969 Accessory Type Wall Plate Technology Cat5/5e; Cat6; Cat6a; DisplayPort; HDBaseT; HDMI; USB Country/Region France PHYSICAL 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Color White Material of Construction ABS Total Number of Ports 0 Unit Dimensions (hwd / in.) 5.140 x 3.140 x 0.780 Unit Dimensions (hwd / mm) OUTER: 130.5 x 80 x 20; INNER: 90 X 45 Finish Matte ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -40° to 154°F (-40° to 68°C) Operating Humidity Range 10% to 90% RH, (Non-Condensing) Storage Humidity Range 10% to 90% RH, (Non-Condensing) FEATURES & SPECIFICATIONS Antibacterial No Snagless Connector No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS; REACH; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N042F-WF2 价格&库存
很抱歉,暂时无法提供与“N042F-WF2”相匹配的价格&库存,您可以联系我们找货
N042F-WF2
  • 1+100.479451+12.99855
库存:1
