1000 Eaton Boulevard
Cleveland, OH 44122
United States
Industrial Cat6 UTP Ethernet Cable (RJ45 M/M),
100W PoE, CMR-LP, IP68, Blue, 50 ft. (15.24 m)
MODEL NUMBER: N200P-050BL-IND
Highlights
Protects Ethernet and digital
signage applications in outdoor
or harsh environments
IP68-rated to resist dust and
endure immersion in 1.5 m of
water up to 60 min.
Supports 100W PoE (71W at
device end) to save you
expense of powering devices
individually
UL CMR-LP certified to meet
high-temperature safety
standards in PoE applications
Color-coded blue for fast, easy
identification in a crowded rack
or patch panel
Applications
Connects Gigabit Ethernet and PoE equipment in industrial environments that require protection against
dust and moisture.
Connect Gigabit Ethernet
networks or digital signage in
factories, warehouses, recycling
plants, machine shops and other
dusty environments
Provide Cat6 connectivity in
outdoor environments
susceptible to rain, such as a
stadium or outdoor arena
Deliver power to PoE devices
mounted in areas that are
difficult to reach or have no
electrical outlets
Save money by installing
industrial cables that support
both power and data, rather
than separate power and data
cables
Features
Cat6 Cable Recommended for Outdoor or Harsh Indoor EnvironmentsThis 50-ft. (15.2 m) Cat6 CMRLP outdoor cable is ideal for connecting Gigabit Ethernet networks or digital signage in outdoor
applications and other areas where protection from harsh elements is essential, such as factories,
warehouses, recycling plants, machine shops and other dusty environments. The RJ45 connectors
feature durable enclosures designed to withstand dust, debris and moisture that could threaten your IT
infrastructure. Included dust caps protect the connectors when not in use.
IP68 Rating Denotes Resistance to Dust and WaterThe IP68 rating means the Cat6 cable is not only
100% protected against dust, but also able to endure immersion in 1.5 meters of water for up to 60
minutes with no damage or decline in performance. For applications that require IP68 protection, use the
industrial cable with a N206-SB01-IND surface-mount box and a N206-BC01-IND bulkhead coupler or
N206-KJ01-IND keystone jack. If only IP44 protection against splashing water from all directions is
required, pair the cable with a N206-FP01-IND, N206-FP02-IND or N206-FP04-IND metal wall plate and a
N206-BC01-IND bulkhead coupler or N206-KJ01-IND keystone jack.
Supports Power over Ethernet to Save You Money and Give You More Installation ChoicesBecause
this Cat6 cable supports High-Power 100W PoE (71W at device end), it can supply the power to operate
compatible data, voice, security and audio/video PoE devices, such as security cameras, VoIP telephones
and access control devices. This saves you the expense and effort of purchasing, connecting and
installing individual power supplies for each device. It also helps you install PoE devices in areas far away
from AC outlets, such as poles or ceilings.
CMR-LP Certified for Cable Installations with Increased Power LevelsUL's Limited Power (LP)
certification indicates the N200P-050BL-IND has been evaluated to handle the marked current under
installation scenarios without exceeding the temperature rating of the cable. This CMR-LP-certified cable
provides a simple way to prepare installations for increased power levels without having to worry about
susceptible issues caused by excessive heat.
Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis Cat6 UTP patch cable
features a blue PVC jacket. The color-coding allows easy, fast identification in a crowded rack, patch
panel or workstation and helps prevent the cable from becoming inadvertently disconnected.
1/3
Package Includes
N200P-050BL-IND Industrial
Cat6 UTP Patch Cable - RJ45
M/M, 50-ft. (15.24 m)
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332251992
Technology
Cat6; PoE
POWER
Power Over Cable (PoC) Support
No
PHYSICAL
Cable Jacket Color
Blue
Cable Jacket Material
PVC
Cable Jacket Rating
CMR-LP; LP5
Cable Shielding
UTP
Cable Outer Diameter (OD)
6.5 mm
Number of Conductors
4 Pair
Conductor Material
Solid Copper
Conductor Gauge
23 AWG
Cable Length (ft.)
50
Cable Length (m)
15.24
Cable Length (in.)
600
Cable Length (cm)
1524
Unit Dimensions (hwd / in.)
12.000 x 10.000 x 0.500
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
-4° to 158°F (-20° to 70°C)
Relative Humidity
0% to 90% RH
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
250 MHz
Maximum Bandwidth as Tested
500 MHz
Network Compatibility
1 Gbps (Gigabit)
2/3
Cleveland, OH 44122
United States
IEEE Standards Supported
802.3bt
CONNECTIONS
PoE Capability
100W (802.3bt); 15.4W (802.3af); 30W (802.3at); 60W (802.3bt)
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Connector Plating
Gold
Contact Plating
Gold
PoE Type
Type 3 PoE++/UPoE (60W, IEEE 802.3bt)
Connector Type
Molded
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
No
Snagless Connector
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Protection Rating
IP68
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3bt PoE++; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N200P-050BL-IND”相匹配的价格&库存,您可以联系我们找货
