N200-UR05-BL
N200-UR05-BL
    TRIPPLITE
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 5,00'(1,52m) 无屏蔽
N200-UR05-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Molded Ultra-Slim UTP Ethernet Cable (RJ45 M/M), Blue, 5 ft. (1.52 m) MODEL NUMBER: N200-UR05-BL Highlights ● Premium Cat6 cable rated for high-speed 1 Gbps home/office communications ● Over 50% slimmer than standard Cat6 cables to increase airflow in full racks ● Easy to route around corners and through crowded cable management panels ● 32 AWG copper wire and 3 µm gold-plated connectors allow superior signal transfer ● Color-coded blue for fast, easy identification in a crowded rack or workstation Applications ● Connect a computer and its peripherals to a home or office Gigabit Ethernet network ● Connect switches, modems and servers in a high-density data center ● Replace standard-diameter cables in crowded racks and patch panel installations to improve airflow Cat6 Ethernet cable, just 2.8 mm thick, connects critical components, such as servers, switches and routers, in Gigabit networks. Features Cat6 Cable Ideal for Connecting Equipment in Your Gigabit Ethernet NetworkThis Cat6 Ethernet cable with RJ45 connectors is recommended for connecting network components like printers, computers, copiers, routers, servers, modems and switches in high-density data centers. Designed for fast transmission and excellent signal quality, this five-foot cable ensures peak performance throughout your local area network (LAN). Special Ultra-Slim Design for Better Airflow and Easier InstallationThe N200-UR05-BL is just 2.8 millimeters in diameter—more than 50% smaller than standard Cat6 cable. This increases airflow in crowded equipment racks, which helps keep your components cool and properly functioning. The extraslim design also makes the cable easier to install around corners and through cable management panels. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThe PVC jacket is colored blue to allow easy, fast identification in a crowded rack or workstation and help prevent the cable from becoming inadvertently disconnected. Premium Construction for Superior PerformanceManufactured from 32 AWG copper wire, the fourpair stranded cable is rated for speeds up to 1 Gbps. The ends feature 3-micron gold plating to help ensure the most accurate signal transfer possible. Integral strain relief gives the unshielded cable extra flexibility, reduces stress, and helps the cable move freely without cracking or breaking loose from the connector. Specifications OVERVIEW UPC Code 037332256935 Technology Cat6 1/3 Package Includes ● N200-UR05-BL Cat6 Ultra-Slim Ethernet Cable (RJ45 M/M), Blue, 5 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States POWER Power Over Cable (PoC) Support No PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Shielding UTP Cable Outer Diameter (OD) 2.8 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 32 AWG Cable Length (ft.) 5 Cable Length (m) 1.52 Cable Length (in.) 60 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 14° to 104°F (-10° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold Connector Type Molded Wiring Configuration EIA/TIA 568B 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N200-UR05-BL 价格&库存
很抱歉,暂时无法提供与“N200-UR05-BL”相匹配的价格&库存,您可以联系我们找货
