N201P-030-BL
N201P-030-BL
    TRIPPLITE
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 30.00'(9.14m) 无屏蔽
N201P-030-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Snagless Molded UTP Ethernet Cable (RJ45 M/M), PoE, CMR-LP, Blue, 30 ft. (9.14 m) Highlights ● Cat6 UTP patch cord rated for high-speed 550 MHz/1 Gbps communications ● Certified Type 4 PoE cable saves you expense and effort of powering PoE devices individually ● Reduces impedance and structural return loss, compared to standard 100 MHz wire ● Snagless RJ45 connectors prevent tabs from being damaged during installation ● Color-coded blue for fast, easy identification in a crowded rack or patch panel MODEL NUMBER: N201P-030-BL Applications Cat6 cable with Power over Ethernet (PoE) connects critical components, such as servers and switches, in Gigabit Ethernet networks. ● Connect a computer and its peripherals to a home or office Gigabit Ethernet network ● Connect switches, modems and servers in a high-density data center ● Deliver power to PoE devices mounted in areas that are difficult to reach or have no electrical outlets Features Cat6 UTP Patch Cable Delivers a Fast, Clear Signal Through Your Gigabit Ethernet NetworkThis Cat6 UTP cable with RJ45 connectors is recommended for connecting network components like printers, adapters, routers, servers, modems, hubs and switches in high-density data centers. Designed for fast transmission and excellent signal quality, this 30-ft. (9.14 m) blue cable ensures peak performance throughout your local area network (LAN). It reduces impedance and structural return loss, compared to standard 100 MHz wire. Supports Power over Ethernet (PoE) to Cut Down on Expensive Power SuppliesBecause this Cat6 cable supports Type 4 PoE, it can supply up to 100W of power to operate compatible PoE devices, such as security cameras, VoIP telephones, point-of-sale kiosks and access control devices. This saves you the expense and effort of purchasing, connecting and installing individual power supplies for each device. Snagless RJ45 Male Connectors Add Extra Protection During InstallationThe RJ45 connectors' snagless design protects the locking tabs from being damaged or broken off during installation. Integral strain relief gives the N201P-030-BL extra flexibility, reduces stress, and helps the cable move freely without cracking or breaking loose from the connector. CMR-LP Certified for Cable Installations with Increased Power LevelsUL's Limited Power (LP) certification indicates the N201P-030-BL has been evaluated to handle the marked current under installation scenarios without exceeding the temperature rating of the cable. This CMR-LP-certified cable provides a simple way to prepare installations for increased power levels without having to worry about susceptible issues caused by excessive heat. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis Cat6 UTP patch cable features a blue PVC jacket. The color-coding allows easy, fast identification in a crowded rack, patch panel or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications 1/3 Package Includes ● N201P-030-BL Cat6 Snagless UTP Network Patch Cable (RJ45 M/M), Blue, 30-ft. (9.14 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332242495 Technology Cat6; PoE PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CMR-LP Cable Shielding UTP Cable Outer Diameter (OD) 6.5 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 23 AWG Cable Length (ft.) 30 Cable Length (m) 9.15 Cable Length (in.) 360 Cable Length (cm) 914.4 Shipping Weight (kg) 0.37 Unit Dimensions (hwd / in.) 10.000 x 8.000 x 0.500 ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -4° to 158°F (-20° to 70°C) Relative Humidity 0% to 90% RH, Non-Condensing Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3bt CONNECTIONS PoE Capability 100W (802.3bt) Side A - Connector 1 RJ45 (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 4 High-Power (100W, IEEE 802.3bt) Connector Type Snagless; Molded Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector Yes STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3bt PoE++; REACH; UKCA; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N201P-030-BL 价格&库存
很抱歉,暂时无法提供与“N201P-030-BL”相匹配的价格&库存,您可以联系我们找货
