N201-S06-BK
N201-S06-BK
    TRIPPLITE
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 6.00'(1.83m) 无屏蔽
N201-S06-BK 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Snagless Slim UTP Ethernet Cable (RJ45 M/M), PoE, Black, 6 ft. (1.83 m) MODEL NUMBER: N201-S06-BK Highlights ● Cat6 UTP patch cord rated for high-speed 1 Gbps communications ● Over 38% slimmer than standard Cat6 cables to increase airflow in full racks ● Easy to route around corners and through crowded cable management panels ● Snagless RJ45 connectors prevent tabs from being damaged during installation ● Color-coded black for fast, easy identification in a crowded rack or workstation Applications ● Connect a computer and its peripherals to a home or office Gigabit Ethernet network ● Connect switches, modems and servers in a high-density data center Cat6 UTP patch cord connects critical components, such as servers, switches, routers, computers and hubs, in Gigabit Ethernet networks. Package Includes Features ● Cat6 UTP Patch Cable Ideal for Your Gigabit Ethernet Network.This Cat6 UTP cable with RJ45 connectors is recommended for connecting network components like printers, computers, copiers, routers, servers, modems and switches in high-density data centers. Designed for fast transmission and excellent signal quality, this six-foot black cable ensures peak performance throughout your local area network (LAN). Special Slim Design for Better Airflow and Easier InstallationThis Cat6 UTP patch cord is more than 38% smaller in diameter than standard Cat6 cable. This increases airflow in tight spaces, which helps keep your equipment cool and properly functioning. It also makes the cable easier to install around corners and through cable management panels. Snagless RJ45 Male Connectors Add Extra ProtectionThe RJ45 connectors’ snagless design protects the locking tabs from being damaged or broken off during installation. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis Cat6 UTP patch cable features a black PVC jacket. The color-coding allows easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected. Premium Construction for Superior PerformanceManufactured from 28 AWG copper wire, the fourpair stranded cable is rated for speeds up to 1 Gbps. The ends feature 50-micron gold plating to help ensure the most accurate signal transfer possible. Integral strain relief gives the unshielded cable extra flexibility, reduces stress, and helps the cable move freely without cracking or breaking loose from the connector. Lifetime WarrantyThe N201-S06-BK is backed by a limited lifetime warranty, ensuring reliability and performance. Specifications 1/3 N201-S06-BK Cat6 UTP Patch Cable RJ45 (M/M), 6 ft., Black 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332226174 Technology Cat6; PoE PHYSICAL Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 3.8 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 28 AWG Wire Gauge (OD - mm²) 3.8 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.09 Shipping Weight (kg) 0.04 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 550 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab; 802.3af; 802.3at CONNECTIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PoE Capability 15.4W (802.3af); 30W (802.3at) Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 1 PoE (15.4W, IEEE 802.3af); Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector Yes STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3af PoE; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N201-S06-BK 价格&库存
很抱歉,暂时无法提供与“N201-S06-BK”相匹配的价格&库存,您可以联系我们找货
