1000 Eaton Boulevard
Cleveland, OH 44122
United States
Up/Down-Angle Cat6 Gigabit Molded UTP
Ethernet Cable (RJ45 Up-Angle M to RJ45 DownAngle M), Blue, 3 ft. (0.91 m)
MODEL NUMBER: N204-003-BL-UD
Highlights
Cat6 Ethernet patch cable
delivers fast transmission
speeds up to 1 Gbps in your
LAN
Up-angle and down-angle RJ45
ends easy to plug into devices
pressed against a wall
Designed for home or office
10/100/1000Base-T Gigabit
Ethernet networks
Color-coded blue for fast, easy
identification in a crowded rack
or workstation
Applications
Cat6 UTP patch cord connects Gigabit Ethernet network components like routers, servers, and switches
in high-density data centers.
Features
Cat6 Patch Cable Connects Equipment in Data Centers and VoIP NetworksThis Cat6 UTP patch
cable is ideal for connecting network components, such as printers, computers, copiers, routers, servers,
modems and switches, in high-density data centers. Designed for fast transmission and excellent signal
quality, this RJ45 patch cable ensures data transfer speeds up to 1 Gbps throughout your Gigabit
Ethernet or VoIP network.
Build a Gigabit Ethernet or VoIP
network through the connection
of routers, modems, switches
and servers in a high-density
data center
Connect a workstation computer
to the company server to gain
access to printers, scanners and
copiers
Combine with other Tripp Lite
patch cables to set up a colorcoded system in a crowded rack
Create a connection in a tight
space, such as a repurposed
server room or behind furniture
Package Includes
Up- and Down-Angle RJ45 Patch Cable Makes Connecting and Disconnecting EasierBoth RJ45
male connectors are designed at 90-degree angles: one upward, the other downward. This helps prevent
excessive bending and reduce stress on the cable. The space-saving cable is easy to plug into patch
panels, switches and other devices located in a confined area or behind a desk.
Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis Cat6 patch cable
features a blue PVC jacket and molded blue ends. The color-coding allows easy, fast identification in a
crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected.
Specifications
OVERVIEW
UPC Code
037332237811
Technology
Cat6
PHYSICAL
Cable Jacket Color
Blue
Cable Jacket Material
PVC
1/3
N204-003-BL-UD Cat6 UTP
Patch Cable, Up-Angle
Male/Down-Angle Male - 3 ft.,
Blue
Cleveland, OH 44122
United States
Cable Jacket Rating
CM
Cable Shielding
UTP
Cable Outer Diameter (OD)
6.0 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
24 AWG
Wire Gauge (OD - mm²)
6.0
Cable Length (ft.)
3
Cable Length (m)
0.91
Cable Length (in.)
36
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Weight (lbs.)
0.12
Shipping Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Relative Humidity
0% to 90% RH, Non-Condensing
Operating Humidity Range
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
250 MHz
Maximum Bandwidth as Tested
500 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3an; 802.3at
CONNECTIONS
PoE Capability
30W (802.3at)
Side A - Connector 1
RJ45 (MALE) - DOWN ANGLE
Side B - Connector 1
RJ45 (MALE) - UP ANGLE
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Molded
Wiring Configuration
EIA/TIA 568B
2/3
Cleveland, OH 44122
United States
Angled Connector
Yes
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
No
Snagless Connector
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N204-003-BL-UD”相匹配的价格&库存,您可以联系我们找货
