N204-020-BL-UP
N204-020-BL-UP
    TRIPPLITE
    模块化电缆 插头至插头,上侧成角 8p8c(RJ45,以太网) 20.00'(6.10m) 无屏蔽
N204-020-BL-UP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Up-Angle Cat6 Gigabit Molded UTP Ethernet Cable (RJ45 Right-Angle Up M to RJ45 M), Blue, 20 ft. (6.09 m) MODEL NUMBER: N204-020-BL-UP Highlights ● Cat6 Ethernet patch cable delivers fast transmission speeds up to 1 Gbps in your LAN ● Up-angle RJ45 connector is easy to plug into switch or panel pressed against a wall ● Designed for home or office 10/100/1000Base-T Gigabit Ethernet networks ● Color-coded blue for fast, easy identification in a crowded rack or workstation Applications Cat6 cable connects Gigabit Ethernet network components like routers, servers, and switches in highdensity data centers. Features Up-Angle Cat6 UTP Cable Connects Equipment in Data Centers and VoIP NetworksThis Cat6 Ethernet cable is ideal for connecting network components, such as printers, computers, copiers, routers, servers, modems and switches, in high-density data centers. Designed for fast transmission and excellent signal quality, this RJ45 cable ensures data transfer speeds up to 1 Gbps throughout your Gigabit Ethernet or VoIP network. ● Build a Gigabit Ethernet or VoIP network through the connection of routers, modems, switches and servers in a high-density data center ● Connect a workstation computer to the company server to gain access to printers, scanners and copiers ● Combine with other Tripp Lite patch cables to set up a colorcoded system in a crowded rack ● Create a connection in a tight space, such as a repurposed server room or behind furniture Package Includes ● Up-Angle RJ45 End Makes Connecting and Disconnecting EasierOne RJ45 connector is designed at a 90-degree up angle, which prevents excessive bending and reduces stress on the cable. This makes the space-saving cable easy to plug into patch panels, switches and other devices located in a confined area or behind a desk. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis long Ethernet cable features a blue PVC jacket and molded blue ends. The color-coding allows easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332252074 Technology Cat6 PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC 1/3 N204-020-BL-UP Up-Angle Cat6 Ethernet Cable - 20-ft. (6.09 m), M/M, Blue 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 24 AWG Cable Length (ft.) 20 Cable Length (m) 6.10 Cable Length (in.) 240 Cable Length (cm) 609 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Relative Humidity 0% to 90% RH, Non-Condensing Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS PoE Capability 30W (802.3at) Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) - UP ANGLE Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Molded Wiring Configuration EIA/TIA 568B Angled Connector Yes FEATURES & SPECIFICATIONS Antibacterial No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States IP68 Rated No Snagless Connector No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N204-020-BL-UP 价格&库存
很抱歉,暂时无法提供与“N204-020-BL-UP”相匹配的价格&库存,您可以联系我们找货
