N204-S10-BL-LA
N204-S10-BL-LA
    TRIPPLITE
    模块化电缆 插头至插头,左侧成角,90° 8p8c(RJ45,以太网) 10.00'(3.05m) 无屏蔽
N204-S10-BL-LA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Left-Angle Cat6 Gigabit Molded Slim UTP Ethernet Cable (RJ45 Left-Angle M to RJ45 M), Blue, 10 ft. (3.05 m) MODEL NUMBER: N204-S10-BL-LA Highlights ● Cat6 Ethernet patch cable delivers fast transmission speeds up to 1 Gbps in your LAN ● Left-angle RJ45 connector is easy to plug into switch or panel pressed against a wall ● Over 38% slimmer than standard Cat6 cables to increase airflow in full racks ● Easy to route around corners and through crowded cable management panels ● Cable is blue for fast, easy identification in a crowded rack or workstation Applications Cat6 cable connects Gigabit Ethernet network components like routers, servers and switches in highdensity data centers. Features Left-Angle Cat6 Ethernet Cable Connects Equipment in Data Centers and VoIP NetworksThis Cat6 cable is ideal for connecting network components, such as printers, computers, copiers, routers, servers, modems and switches, in hard-to-reach areas of space-constrained high-density data centers. Designed for fast transmission and excellent signal quality, this RJ45 patch cable ensures data transfer speeds up to 1 Gbps throughout your Gigabit Ethernet or VoIP network. Special Slim Design for Better Airflow and Easier Installation in Crowded RacksThis Cat6 UTP patch cord is more than 38% smaller in diameter than standard Cat6a cable. This increases airflow in tight spaces, which helps keep your equipment cool and properly functioning. It also cuts down on clutter in crowded racks and patch panels, and makes the cable easier to install around corners and through cable management panels. Left-Angle RJ45 Patch Cable Makes Connecting and Disconnecting EasierOne RJ45 male connector is designed at a 90-degree left angle, which prevents excessive bending and reduces stress on the cable. This makes the space-saving cable easy to plug into patch panels, switches and other devices located in a confined area or behind a desk. Blue Jacket to Avoid Misidentification That Can Cause Costly DowntimeThis left-angle Cat6 Ethernet cable features a blue PVC jacket and molded blue ends. The blue color allows easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332252333 Technology Cat6 1/3 ● Build a Gigabit Ethernet or VoIP network through the connection of routers, modems, switches and servers in a high-density data center ● Connect a workstation computer to the company server to gain access to printers, scanners and copiers ● Combine with other Tripp Lite patch cables to set up a colorcoded system in a crowded rack ● Create a connection in a tight space, such as a repurposed server room or behind furniture Package Includes ● N204-S10-BL-LA Left-Angle Cat6 Gigabit Molded Slim UTP Patch Cable (M/M), Blue, 10 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 4.0 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 28 AWG Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Cable Length (cm) 304 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (kg) 0.07 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Relative Humidity 0% to 90% RH, Non-Condensing Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) - LEFT ANGLE Crossover Wiring No Contact Plating Gold Connector Type Molded 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Wiring Configuration EIA/TIA 568B Angled Connector Yes FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N204-S10-BL-LA 价格&库存
很抱歉,暂时无法提供与“N204-S10-BL-LA”相匹配的价格&库存,您可以联系我们找货
