1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6 Gigabit Solid Core UTP Bulk Ethernet
Cable, CMP-LP 0.5A Plenum, 100W PoE/PoE++,
White, 1000 ft. (304.8 m)
Highlights
UL-listed CMP-LP (0.5A)
plenum-rated jacket certified for
PoE++ and high-power PoE
Recommended for horizontal
premise installations in air ducts
and drop ceilings
23 AWG 4-pair solid copper
cable rated for 550 MHz/1 Gbps
Ethernet speeds
Bulk pack of 1000 ft. cable
comes in white for custom colorcoded applications
MODEL NUMBER: N224-01K-WH-LP5
Applications
Premium high-speed Cat6 cable designed for in-wall data, voice, security and audio/video applications,
including 100W high-power PoE.
Features
Connect Gigabit Ethernet
network components, such as
computers, routers and
modems, in air ducts and drop
ceilings in a home, office, school
or church application
Future-proof cable infrastructure
against increasing PoE power
levels
Set up a security application
involving PoE surveillance
cameras
Package Includes
Premium High-Speed Cat6 Cable for Gigabit Ethernet Premise ApplicationsThis high-speed bulk
cable is ideal for Cat6 premise (in-wall) applications in air ducts and drop ceilings in commercial and
residential installations. This includes the distribution of data, voice, security and audio/video across
Gigabit Ethernet networks. Designed for fast transmission and excellent signal quality, this 1000-foot roll
of white cabling ensures peak performance through your LAN. Manufactured from 23 AWG copper wire,
the N224-01K-WH-LP5 delivers speeds up to 550 MHz/1 Gbps.
Designed for PoE++ and High-Power PoE ApplicationsThe plenum-rated CMP-LP jacket meets UL’s
latest Limited Power (LP) standards for 0.5A cables. This ensures the cable will withstand the heat
required to power devices at PoE++ (60W) or High-Power (100W) PoE power levels, no matter the bundle
size or environmental conditions, such as enclosed spaces.
Specifications
OVERVIEW
UPC Code
037332243744
Technology
Cat6; PoE
PHYSICAL
Cable Jacket Color
White
Cable Jacket Material
PVC
Cable Jacket Rating
CMP-LP5
1/3
N224-01K-WH-LP5 Cat6
Ethernet Cable - CMP-LP 0.5A
Plenum, White, 1000 ft.
Cleveland, OH 44122
United States
Cable Shielding
UTP
Cable Outer Diameter (OD)
5.8 mm
Number of Conductors
4 Pair
Conductor Material
Solid Copper
Conductor Gauge
23 AWG
Cable Length (ft.)
1000
Cable Length (m)
304.88
Cable Length (in.)
12000
Cable Length (cm)
30480
ENVIRONMENTAL
Operating Temperature Range
-4° to 167°F (-20° to 75°C)
Storage Temperature Range
32° to 140°F (0° to 60°C)
COMMUNICATIONS
Bandwidth per TIA Standard
250 MHz
Maximum Bandwidth as Tested
500 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3ab; 802.3af; 802.3at; 802.3bt
CONNECTIONS
PoE Capability
100W (802.3bt); 15.4W (802.3af); 30W (802.3at); 60W (802.3bt)
Side A - Connector 1
BARE WIRE
Side B - Connector 1
BARE WIRE
Crossover Wiring
No
PoE Type
Type 3 PoE++/UPoE (60W, IEEE 802.3bt); Type 1 PoE (15.4W, IEEE 802.3af); Type 2 PoE+ (30W, IEEE 802.3at);
Type 4 High-Power (100W, IEEE 802.3bt)
Connector Type
Bare Wire
Angled Connector
No
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
No
Snagless Connector
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3af PoE; IEEE 802.3at PoE+; IEEE 802.3bt PoE++; REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N224-01K-WH-LP5”相匹配的价格&库存,您可以联系我们找货
