N261-06N-GY
N261-06N-GY
    TRIPPLITE
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 0.50'(152.4mm) 无屏蔽
N261-06N-GY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a 10G Snagless Molded UTP Ethernet Cable (RJ45 M/M), PoE, Gray, 6 in. (15 cm) MODEL NUMBER: N261-06N-GY Highlights ● Cat6a UTP Ethernet cable rated for high-speed 10 Gbps communications ● Supports PoE to save you expense and effort of powering PoE devices individually ● Allows installation of PoE devices in hard-to-reach areas or away from AC outlets ● Snagless RJ45 connectors prevent tabs from being damaged during installation ● Gray jacket permits fast, easy identification in a crowded switch or patch panel Package Includes N261-06N-GY Cat6a 10G Snagless Molded UTP Ethernet Cable (RJ45 M/M), PoE, Gray, 6 in. (15 cm) Ethernet cable with Power over Ethernet (PoE) connects critical components, such as servers, switches, routers and hubs, in high-density 10G networks. Features Cat6a Cable Ideal for Your High-Density 10 Gigabit Ethernet Network This Cat6a 10G Ethernet cable with RJ45 connectors is recommended for connecting network components like printers, computers, copiers, routers, servers, modems, hubs and switches in highdensity data centers and network closets. Designed for fast transmission and excellent signal quality, the N261-06N-GY ensures peak performance throughout your LAN. Supports Power over Ethernet to Save You Money and Give You More Installation Choices Because this Cat6a cable supports PoE, it can supply the power to operate compatible PoE devices, such as security cameras, VoIP telephones, point-of-sale kiosks and access control devices. This saves you the expense and effort of purchasing, connecting and installing individual power supplies for each device. It also helps you install PoE devices in areas far away from AC outlets, such as poles or ceilings. Snagless RJ45 Male Connectors Add Extra Protection The RJ45 connectors’ snagless design protects the locking tabs from being damaged or broken off during installation. The contacts feature 50-micron gold plating to help ensure the most accurate signal transfer possible, improving near-end crosstalk (NEXT) performance to 500 MHz. Gray Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The cable has a gray PVC jacket, which is easy to identify quickly in a crowded patch panel or switch and helps prevent the cable from becoming accidentally disconnected. Premium Construction for Superior Performance Manufactured from 24 AWG copper wire, the four-pair stranded cable is rated for speeds up to 10 Gbps. Integral strain relief gives the unshielded cable extra flexibility, reduces stress and helps the cable move freely without cracking or breaking loose from the connector. Specifications OVERVIEW 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332277664 Technology Cat6a; PoE PHYSICAL Cable Jacket Color Gray Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 24 AWG Cable Length (ft.) 0.5 Cable Length (m) 0.15 Cable Length (in.) 6 Cable Length (cm) 30.5 ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 500 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 10 Gbps IEEE Standards Supported 802.3ab; 802.3an; 802.3af; 802.3at CONNECTIONS PoE Capability 15.4W (802.3af); 30W (802.3at) Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Connector Plating Nickel Contact Plating Gold PoE Type Type 1 PoE (15.4W, IEEE 802.3af); Type 2 PoE+ (30W, IEEE 802.3at) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Type Molded; Snagless Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector Yes STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3af PoE; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N261-06N-GY 价格&库存
很抱歉,暂时无法提供与“N261-06N-GY”相匹配的价格&库存,您可以联系我们找货
