N261P-010-BL
N261P-010-BL
    TRIPPLITE
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 10.00'(3.05m) 屏蔽
N261P-010-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a 10G Snagless F/UTP Ethernet Cable (RJ45 M/M), PoE, CMR-LP, Blue, 10 ft. (3.05 m) MODEL NUMBER: N261P-010-BL Highlights ● Cat6a F/UTP patch cord rated for high-speed 10 Gbps communications ● Certified Type 4 PoE cable saves you expense and effort of powering PoE devices individually ● Dispels EMI/RFI line noise that can destroy data and affect equipment performance ● Snagless RJ45 connectors prevent tabs from being damaged during installation ● Color-coded blue for fast, easy identification in a crowded rack or patch panel Applications Cat6a cable with Power over Ethernet (PoE) connects 10G equipment, such as webcams and VoIP phones, in high-speed 10GBase-T networks. ● Connect 10GBase-T networks or digital signage in a highdensity data center ● Deliver power to PoE devices, including security cameras and VoIP phones, mounted in areas that are difficult to reach or have no electrical outlets ● Provide universal connectivity for LAN network components, such as switches, servers, modems, routers, adapters, VoIP phones, security cameras and point-of-sale kiosks Features High-Speed Cat6a F/UTP (FTP) Patch Cable Ideal for Your 10GBase-T Ethernet NetworkThis Cat6a F/UTP cable with RJ45 connectors transmits 10 Gbps data, voice and video through high-speed 10G equipment, including network switches, modems, routers, adapters, hubs and patch panels. Designed for fast transmission and excellent signal quality, this 10-ft. (3.05 m) blue cable ensures peak performance throughout your local area network (LAN). It reduces impedance and structural return loss, compared to standard 100 MHz wire. Supports Power over Ethernet (PoE) to Cut Down on Expensive Power SuppliesBecause this Cat6a cable supports Type 4 PoE, it can supply up to 100W of power to operate compatible PoE devices, such as security cameras, VoIP telephones, point-of-sale kiosks and access control devices. This saves you the expense and effort of purchasing, connecting and installing individual power supplies for each device. Premium Protection from EMI/RFI and Other Noise Helps Your Equipment Perform BetterVarious electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems. The F/UTP cable's foil shielding blocks disruptive line noise that can disturb your electronics and inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Nearend crosstalk (NEXT) levels are practically eliminated, so you don't have to worry about keeping your cables separated in crowded pathways or spend valuable time on field testing. Snagless RJ45 Male Connectors Add Extra Protection During InstallationThe RJ45 connectors' snagless design protects the locking tabs from being damaged or broken off during installation. Integral strain relief gives the N261P-010-BL extra flexibility, reduces stress, and helps the cable move freely without cracking or breaking loose from the connector. CMR-LP Certified for Cable Installations with Increased Power LevelsUL's Limited Power (LP) certification indicates the N261P-010-BL has been evaluated to handle the marked current under installation scenarios without exceeding the temperature rating of the cable. This CMR-LP-certified cable provides a simple way to prepare installations for increased power levels without having to worry about susceptible issues caused by excessive heat. 1/3 Package Includes ● N261P-010-BL Cat6a 10GCertified Snagless F/UTP Network Patch Cable (RJ45 M/M), Blue, 10-ft. (3.05 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis Cat6a F/UTP patch cable features a blue PVC jacket. The color-coding allows easy, fast identification in a crowded rack, patch panel or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332242532 Technology Cat6a; PoE PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CMR-LP Cable Shielding F/UTP Cable Outer Diameter (OD) 7.3 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 23 AWG Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Cable Length (cm) 304.8 Shipping Weight (kg) 0.13 Unit Dimensions (hwd / in.) 9.000 x 7.000 x 0.500 ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -4° to 158°F (-20° to 70°C) Relative Humidity 0% to 90% RH, Non-Condensing Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 500 MHz Maximum Bandwidth as Tested 600 MHz Network Compatibility 10 Gbps 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States IEEE Standards Supported 802.3an; 802.3bt CONNECTIONS PoE Capability 100W (802.3bt) Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Connector Plating Nickel Contact Plating Gold PoE Type Type 4 High-Power (100W, IEEE 802.3bt) Connector Type Molded; Snagless Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector Yes STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3bt PoE++; REACH; UKCA; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N261P-010-BL 价格&库存
很抱歉,暂时无法提供与“N261P-010-BL”相匹配的价格&库存,您可以联系我们找货
