N261-S20-BL
N261-S20-BL
    TRIPPLITE
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 20.00'(6.10m) 无屏蔽
N261-S20-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a 10G Snagless Molded Slim UTP Ethernet Cable (RJ45 M/M), Blue, 20 ft. (6.09 m) MODEL NUMBER: N261-S20-BL Highlights ● Cat6a UTP Ethernet patch cable rated for high-speed 10 Gbps communications ● Over 38% slimmer than standard Cat6a cables to increase airflow in full racks ● Easy to route around corners and through crowded cable management panels ● Snagless RJ45 connectors prevent tabs from being damaged during installation ● Color-coded blue for fast, easy identification in a crowded rack or workstation Applications ● Connect a computer and its peripherals to a home or office 10G network ● Connect switches, modems and servers in a high-density data center, telecom room or network closet ● Replace standard-diameter cables in crowded patch panel installations to improve airflow Slim Cat6a cable connects critical components, such as servers, switches, routers and hubs, in highdensity 10G Ethernet networks. Features Cat6a Cable Ideal for Your High-Density 10 Gigabit Ethernet NetworkThis Cat6a 10G Ethernet cable with RJ45 connectors is recommended for connecting network components like printers, computers, copiers, routers, servers, modems, hubs and switches in high-density data centers and network closets. Designed for fast transmission and excellent signal quality, this 20-ft. (6.09 m) blue cable ensures peak performance throughout your LAN. Special Slim Design for Better Airflow and Easier InstallationThis Cat6a UTP patch cord is more than 38% smaller in diameter than standard Cat6a cable. This increases airflow in tight spaces, which helps keep your equipment cool and properly functioning. It also cuts down on clutter in crowded racks and patch panels, and makes the cable easier to install around corners and through cable management panels. Snagless RJ45 Male Connectors Add Extra ProtectionThe RJ45 connectors' snagless design protects the locking tabs from being damaged or broken off during installation. The ends feature 50-micron gold plating to help ensure the most accurate signal transfer possible, improving near-end crosstalk (NeXT) performance to 500 MHz. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThe N261-S20-BL features a blue PVC jacket. The color-coding allows easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected. Premium Construction for Superior PerformanceManufactured from 28 AWG copper wire, the fourpair stranded cable is rated for speeds up to 10 Gbps. Integral strain relief gives the unshielded cable extra flexibility, reduces stress, and helps the cable move freely without cracking or breaking loose from the connector. Specifications OVERVIEW 1/3 Package Includes ● N261-S20-BL Cat6a 10G Snagless Molded Slim UTP Network Patch Cable (M/M), Blue, 20-ft. (6.09 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332251794 Technology Cat6a PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Shielding UTP Cable Outer Diameter (OD) 3.8 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 28 AWG Cable Length (ft.) 20 Cable Length (m) 6.10 Cable Length (in.) 240 Cable Length (cm) 609.6 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Relative Humidity 0% to 90% RH, Non-Condensing Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 500 MHz Maximum Bandwidth as Tested 600 MHz Network Compatibility 10 Gbps IEEE Standards Supported 802.3an CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold Connector Type Snagless; Molded Wiring Configuration EIA/TIA 568B Angled Connector No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector Yes STANDARDS & COMPLIANCE Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N261-S20-BL 价格&库存
很抱歉,暂时无法提供与“N261-S20-BL”相匹配的价格&库存,您可以联系我们找货
