1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6a 10G Snagless Shielded STP Ethernet
Cable (RJ45 M/M), PoE, Black, 2 ft. (0.61 m)
MODEL NUMBER: N262-002-BK
Highlights
Cat6a STP patch cord rated for
high-speed 10 Gbps
communications
Ideal for connecting 10G
network switches, routers, hubs
and other equipment
Supports PoE to save you
expense and effort of powering
PoE devices individually
Dispels EMI/RFI line noise that
can destroy data and affect
equipment performance
Snagless RJ45 connectors
prevent tabs from being
damaged during installation
Applications
Connect 10GBase-T networks
or digital signage in a highdensity data center
Deliver power to PoE devices
mounted in areas that are
difficult to reach or have no
electrical outlets
Replace an old or missing RJ45
cable
Provide universal connectivity
for LAN network components,
such as switches, servers,
modems, routers, adapters,
VoIP phones, security cameras
and point-of-sale kiosks
Snagless Cat6a cable with Power over Ethernet (PoE) connects 10G equipment in your high-speed
10GBase-T network.
Features
High-Speed Cat6a STP Patch Cable Ideal for Your 10GBase-T Ethernet NetworkDesigned for fast
transmission and excellent signal quality, this two-foot Cat6a cable ensures peak performance throughout
your local area network (LAN). It transmits 10 Gbps data, voice and video through high-speed 10G
equipment, including network switches, modems, routers, adapters, hubs and patch panels. At 500 MHz,
it reduces impedance and structural return loss compared to standard 100 MHz wire.
Supports Power over Ethernet to Save You Money and Give You More Installation ChoicesBecause
this Cat6a shielded cable supports PoE, it can supply the power to operate compatible PoE devices, such
as security cameras, VoIP telephones, point-of-sale kiosks and access control devices. This saves you
the expense and effort of purchasing, connecting and installing individual power supplies for each device.
It also helps you install PoE devices in areas far away from AC outlets, such as poles or ceilings.
Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform BetterVarious
electromagnetic and radio sources found in virtually every home and business can cause disruptive
interference. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this
line noise is a common cause of performance problems. The N262-002-BK shields against disruptive line
noise that can disturb your electronics and inflict hardware damage or data loss. This EMI/RFI filtering
also helps your connected components perform better and last longer.
Snagless RJ45 Male Connectors Add Extra Protection During InstallationThe RJ45 connectors’
snagless design protects the locking tabs from being damaged or broken off during installation. The ends
are shielded to minimize near-end crosstalk (NEXT) levels. Integral strain relief gives the N262-002-BK
extra flexibility, reduces stress and helps the cable move freely without cracking or breaking loose from
the connector.
Specifications
OVERVIEW
1/3
Package Includes
N262-002-BK Cat6a 10GCertified Snagless Shielded
STP Network Patch Cable
(RJ45 M/M), Black, 2 ft.
Cleveland, OH 44122
United States
UPC Code
037332256652
Technology
Cat6a; PoE
PHYSICAL
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
STP
Cable Outer Diameter (OD)
6.2 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
26 AWG
Cable Length (ft.)
2
Cable Length (m)
0.61
Cable Length (in.)
24
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
500 MHz
Maximum Bandwidth as Tested
600 MHz
Network Compatibility
10 Gbps
IEEE Standards Supported
802.3at
CONNECTIONS
PoE Capability
30W (802.3at)
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Connector Plating
Nickel
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Snagless
2/3
Cleveland, OH 44122
United States
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
No
Snagless Connector
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3at PoE+; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N262-002-BK”相匹配的价格&库存,您可以联系我们找货
