N262-S07-BL
N262-S07-BL
    TRIPPLITE
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 7.00'(2.13m) 屏蔽
N262-S07-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a 10G Snagless Shielded Slim STP Ethernet Cable (RJ45 M/M), PoE, Blue, 7 ft. (2.1 m) MODEL NUMBER: N262-S07-BL Highlights ● Cat6a STP Ethernet cable rated for high-speed 10 Gbps communications ● Over 38% slimmer than standard Cat6a cables to increase airflow in full racks ● Allows installation of PoE devices in hard-to-reach areas or away from AC outlets ● Dispels EMI/RFI line noise that can destroy data and affect equipment performance ● Blue jacket permits fast, easy identification in a crowded switch or patch panel Package Includes N262-S07-BL Cat6a 10G Snagless Shielded Slim STP Ethernet Cable (RJ45 M/M), PoE, Blue, 7 ft. (2.1 m) Shielded Cat6a cable connects critical components, such as PoE servers, switches, routers and hubs, in high-density 10G Ethernet networks. Features Cat6a Cable Ideal for Your High-Density 10 Gigabit Ethernet Network This Cat6a 10G Ethernet cable with RJ45 connectors is recommended for connecting network components like printers, computers, copiers, routers, servers, modems, hubs and switches in highdensity data centers and network closets. Designed for fast transmission and excellent signal quality, the N262-S07-BL ensures peak performance throughout your LAN. Supports Power over Ethernet to Save You Money and Give You More Installation Choices Because this Cat6a cable supports PoE, it can supply the power to operate compatible PoE devices, such as security cameras, VoIP telephones, point-of-sale kiosks and access control devices. This saves you the expense and effort of purchasing, connecting and installing individual power supplies for each device. It also helps you install PoE devices in areas far away from AC outlets, such as poles or ceilings. Special Slim Design for Better Airflow and Easier Installation This Cat6a STP patch cord is more than 38% smaller in diameter than standard Cat6a cable. This increases airflow in tight spaces, which helps keep your equipment cool and properly functioning. It also cuts down on clutter in crowded racks and patch panels, and makes the cable easier to install around corners and through cable management panels. Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform Better The N262-S07-BL shields disruptive EMI (electromagnetic interference) and RFI (radio frequency interference) line noise that can disturb your electronics and inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Snagless RJ45 Male Connectors Add Extra Protection The RJ45 connectors’ snagless design protects the locking tabs from being damaged or broken off during installation. The ends are shielded to minimize near-end crosstalk (NEXT) levels. Blue Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The cable has a blue PVC jacket, which is easy to identify quickly in a crowded patch panel or switch and helps prevent the cable from becoming accidentally disconnected. Premium Construction for Superior Performance 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Manufactured from 28 AWG copper wire, the four-pair stranded cable is rated for speeds up to 10 Gbps. Integral strain relief gives the shielded cable extra flexibility, reduces stress and helps the cable move freely without cracking or breaking loose from the connector. Specifications OVERVIEW UPC Code 037332276001 Technology Cat6a; PoE PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding STP Cable Outer Diameter (OD) 5.4 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 28 AWG Cable Length (ft.) 7 Cable Length (m) 2.13 Cable Length (in.) 84 Cable Length (cm) 30.5 ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 500 MHz Maximum Bandwidth as Tested 600 MHz Network Compatibility 10 Gbps IEEE Standards Supported 802.3ab; 802.3an; 802.3af; 802.3at CONNECTIONS PoE Capability 15.4W (802.3af); 30W (802.3at) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Connector Plating Nickel Contact Plating Gold PoE Type Type 1 PoE (15.4W, IEEE 802.3af); Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Molded; Snagless Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector Yes STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3af PoE; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N262-S07-BL
PDF文档中包含的物料型号为N262-S07-BL,是一款Cat6a 10G Snagless Shielded Slim STP Ethernet Cable,长度为7英尺(2.1米),颜色为蓝色。
该电缆支持高速10 Gbps通信,并且具有以下特点:
- 器件简介:Cat6a STP Ethernet cable,推荐用于连接网络组件,如打印机、计算机、复印机、路由器、服务器、调制解调器、集线器和交换机。
- 引脚分配:遵循EIA/TIA 568B标准,RJ45公头连接器,无交叉线。
- 参数特性:支持PoE,提供15.4W(802.3af)和30W(802.3at)的PoE能力,使用28 AWG铜线,4对绞合线,外径5.4毫米。
- 功能详解:电缆设计用于高密度10G以太网网络,支持PoE以节省成本并提供更多安装选择,具有超过38%的更细直径以改善空气流通和简化安装,提供高级EMI/RFI线噪声保护。
- 应用信息:适用于高密度数据中心和网络布线间,支持10Gbps网络兼容性,支持IEEE 802.3ab、802.3an、802.3af和802.3at标准。
- 封装信息:蓝色PVC外皮,STP屏蔽,线缆长度7英尺(2.1米),外径5.4毫米,28 AWG铜线,工作温度范围-20°C至60°C。
此外,该产品提供终身有限保修,并符合UL、cUL、CE、RoHS等认证标准。
N262-S07-BL 价格&库存
很抱歉,暂时无法提供与“N262-S07-BL”相匹配的价格&库存,您可以联系我们找货
