1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat8 25G/40G Certified Snagless Shielded S/FTP
Ethernet Cable (RJ45 M/M), PoE, White, 10 ft.
(3.05 m)
Highlights
Certified Cat8 S/FTP patch cord
rated for 40 Gbps networks—4x
faster than Cat6a
Supports PoE to save you
expense and effort of powering
PoE devices individually
Dispels EMI/RFI line noise that
can destroy data and affect
equipment performance
Snagless RJ45 connectors
prevent tabs from being
damaged during installation
White PVC jacket allows fast,
easy identification in a crowded
rack or workstation
MODEL NUMBER: N272-010-WH
Applications
Connect 40GBase-T networks
or digital signage in your office,
school or retail business’ highdensity server room or data
center
Deliver power to PoE devices,
including network switches,
security cameras and wireless
access points, mounted in areas
that are difficult to reach or have
no electrical outlets
Shielded Cat8 cable connects 25G/40G equipment in your top-of-the-line 40GBase-T data center.
Features
High-Speed Cat8 S/FTP Ethernet Cable Up to 4 Times Faster Than Cat6aThis certified Cat8 cable
transmits 40 Gbps data, voice and audio/video through high-speed 40G equipment, including network
switches, modems, routers, adapters, hubs and patch panels. Not only is its 40 Gbps data transfer speed
four times that of Cat6a cable, but this Cat8 cable also supports bandwidth up to 2 GHz (2000 MHz) for
carrying information and streaming video with no lag.
Supports Power over Ethernet (PoE) to Cut Down on Power SuppliesBecause this Cat8 shielded
cable supports PoE, it can supply the power to operate compatible PoE devices, such as security
cameras, VoIP telephones, point-of-sale kiosks and access control devices. This saves you the expense
and effort of purchasing, connecting and installing individual power supplies for each device. You can also
install PoE devices in locations distant from power outlets, such as high on walls, ceilings or poles.
Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform BetterEMI
(electromagnetic interference) and RFI (radio frequency interference) line noise is a common cause of
performance problems. The 22 AWG S/FTP (shielded foiled twisted pair) cable’s foil shielding blocks
disruptive line noise that can disturb your electronics and inflict hardware damage or data loss. This
EMI/RFI filtering also helps your connected components perform better and last longer. Near-end
crosstalk (NEXT) levels are practically eliminated, so you don’t have to worry about keeping your cables
separated in crowded pathways or spend valuable time on field testing.
Snagless RJ45 Male Connectors Add Extra Protection During InstallationThe RJ45 connectors’
snagless design protects the locking tabs from being damaged or broken off during installation. Integral
strain relief provides extra flexibility, reduces stress and helps the cable move freely without cracking or
breaking loose from the connector.
Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis Cat8 patch cable
features a durable white PVC jacket. The color-coding allows easy, fast identification in a crowded rack,
patch panel or workstation, preventing the cable from becoming accidentally disconnected.
Specifications
1/3
Package Includes
N272-010-WH Cat8 25G/40GCertified Snagless Shielded
White, 10-ft. (3.05 m)
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332249760
Technology
PoE; Cat8
PHYSICAL
Cable Jacket Color
White
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
S/FTP
Cable Outer Diameter (OD)
8.0 mm
Number of Conductors
4 Pair
Conductor Material
Solid Copper
Conductor Gauge
22 AWG
Cable Length (ft.)
10
Cable Length (m)
3.05
Cable Length (in.)
120
Cable Length (cm)
304.8
Shipping Dimensions (hwd / in.)
10.00 x 8.00 x 0.50
Shipping Weight (kg)
0.23
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Relative Humidity
0% to 90% RH, Non-Condensing
Operating Humidity Range
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
1000 MHz
Maximum Bandwidth as Tested
1200 MHz
Network Compatibility
40 Gbps
IEEE Standards Supported
802.3bt
CONNECTIONS
PoE Capability
60W (802.3bt)
Side A - Connector 1
RJ45 (MALE)
2/3
Cleveland, OH 44122
United States
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Connector Plating
Nickel
Contact Plating
Gold
PoE Type
Type 3 PoE++/UPoE (60W, IEEE 802.3bt)
Connector Type
Snagless
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
No
Snagless Connector
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3bt PoE++; REACH; UKCA; Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N272-010-WH”相匹配的价格&库存,您可以联系我们找货
