1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cisco-Compatible SFP+ Transceiver - 10Gbps,
Copper, RJ45, Cat6a, 98 ft. (30 m)
MODEL NUMBER: N286-10G-TC
Highlights
SFP+ transceiver module 100%
compatible with Cisco’s SFP10G-T-X module
Provides 10 Gbps throughput up
to 98 ft. (30 m) via Cat6a cabling
Hot-swappable interface lets
you install and uninstall without
shutting down
Meets or exceeds MSA
standards and works in all MSAcompliant platforms
System Requirements
Cisco or other compatible network
router, server or switch
Package Includes
N286-10G-TC SFP+ Transceiver
Connects a Cat6a 10 Gigabit Ethernet cable to a Cisco router, server or switch’s SFP+ port.
Features
SFP+ Transceiver for Connecting Copper Cabling to Your Cisco Network Switch or Router
This SFP+ transceiver allows you to connect a copper Cat6a cable to a 1/2.5/5/10 Gbps fiber network
router, server or switch. It transmits data up to 98 feet (30 meters) and supports bi-directional Gigabit
Ethernet communication up to 10 Gbps.
Functionally Equivalent to Cisco SFP-10G-T-X Transceiver Module
The MSA-compliant N286-10G-TC functions just like the equivalent Cisco SFP-10G-T-X transceiver
module and is manufactured to meet or exceed Cisco specifications. You can use this transceiver with
any compatible Cisco router, server or switch and receive the same performance as the SFP-10G-T-X.
Hot-Swappable for Installation Without Network Interruption
This input/output device is fully hot-swappable, so you can install it without a potentially costly
1G/2.5G/5G/10G network shutdown or device reboot. Just plug the SFP end of the transceiver into your
Cisco network device. The other end has an RJ45 connector to link with high-speed Cat6a patch cable
(sold separately). A convenient bail clasp latch helps you carefully remove the module from the device.
Premium Features for Superior Performance
The auto-sensing RJ45 port supports auto-negotiation and automatic MDI/MDI-X crossover to match the
other end of the connection. The zinc housing protects against electromagnetic interference (EMI) and
excessive power dissipation.
Specifications
OVERVIEW
UPC Code
037332279330
Brand Compatibility
Cisco
Technology
Cat6a
1/3
Cleveland, OH 44122
United States
POWER
Power Consumption (Watts)
2.60
PHYSICAL
Color
Silver
Material of Construction
Zinc Alloy
Shipping Dimensions (hwd / in.)
0.70 x 3.10 x 5.70
Shipping Weight (lbs.)
0.11
Unit Dimensions (hwd / in.)
0.330 x 0.530 x 2.680
Unit Dimensions (in.)
Unit Packaging Type
Box
ENVIRONMENTAL
Operating Temperature Range
32° to 158°F (0° to 70°C)
Storage Temperature Range
-40° to 185°F (-40° to 85°C)
Operating Humidity Range
5 - 85 % RH
COMMUNICATIONS
Network Compatibility
10 Gbps
Transmission Distance
很抱歉,暂时无法提供与“N286-10G-TC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2232.262371+289.34371
- 10+1965.3964310+254.75280
