1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cisco-Compatible SFP-25G-LR-S SFP28
Transceiver - 25GBase-SR, Singlemode LC, 1310
nm, 10 km (6.2 mi.)
Highlights
SFP28 transceiver module
100% compatible with Cisco’s
equivalent module
Provides 25 Gbps throughput up
to 10 kilometers (6.2 mi.) via
singlemode fiber cabling
LC duplex female connector
supports 25GBase-SR signal at
1310 nm wavelength
Hot-swappable interface lets
you install and uninstall without
shutting down
Meets or exceeds MSA
standards and works in all MSAcompliant platforms
MODEL NUMBER: N286-25G-LR-S
Applications
Links a singlemode Gigabit Ethernet network cable to a Cisco switch or server’s SFP28 port.
System Requirements
Features
SFP28 Transceiver Designed for Connection to Your Cisco Network Switch or ServerThis SFP28
transceiver allows you to connect a singlemode fiber optic cable to a 25 Gbps network router, server or
switch. It transmits data up to 10 kilometers (6.2 miles) using a 1310 nm wavelength. The zinc housing
protects against electromagnetic interference (EMI) and excessive power dissipation.
Functionally Equivalent to Cisco SFP-25G-LR-S Transceiver ModuleThe MSA-compliant N286-25GLR-S functions just like the equivalent Cisco SFP-25G-LR-S transceiver module and is manufactured to
meet or exceed Cisco specifications. You can use this transceiver with any compatible Cisco router,
server or switch and receive the same performance as the SFP-25G-LR-S.
Hot-Swappable for Installation Without Network InterruptionThis input/output device is fully hotswappable, so you can install it without a potentially costly 25 Gbps network shutdown or device reboot.
Just plug the SFP28 end of the transceiver into your Cisco network device. The other end has an LC
duplex connector to link with singlemode fiber optic cable (sold separately). A push/pull tab connector is
easily accessible in high-density data center applications and makes the plug-and-play transceiver easy to
install and remove with one hand.
Specifications
OVERVIEW
UPC Code
037332248961
Brand Compatibility
Cisco
PHYSICAL
Unit Dimensions (hwd / in.)
0.330 x 0.530 x 2.230
1/2
Install an additional LC duplex
port on a Cisco router, server or
switch for the purpose of
connecting a singlemode
Cisco or other compatible
network router, server or switch
Package Includes
N286-25G-LR-S CiscoCompatible SFP-25G-LR-S
SFP28 Transceiver
Cleveland, OH 44122
United States
Unit Dimensions (hwd / cm)
0.85 x 1.34 x 5.66
Unit Dimensions (hwd / mm)
8.5 x 13.4 x 56.6
ENVIRONMENTAL
Operating Temperature Range
32° to 158°F (0° to 70°C)
Storage Temperature Range
-40° to 185°F (-40° to 85°C)
Relative Humidity
5% to 85%
32 to 158 F (0 to 70 C)
COMMUNICATIONS
Network Compatibility
25 Gbps
Wavelength
1310nm
Transmission Distance
10 km
CONNECTIONS
Side A - Connector 1
SFP28 (Male)
Side B - Connector 1
LC DUPLEX (FEMALE)
FEATURES & SPECIFICATIONS
Data Transfer Rate
25 Gbps
Multi-Source Agreement (MSA)
Compliant
Yes
Optical Port
LC
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N286-25G-LR-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+5523.2058710+715.14264
