N286-40G-LR4
N286-40G-LR4
    TRIPPLITE
    FIBER TXRX QSFP+ 40GBPS
N286-40G-LR4 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cisco-Compatible QSFP-40G-LR4 QSFP+ Transceiver - 40GBase-LR4, Singlemode LC, 1270-1330 nm, 10 km Highlights ● QSFP+ transceiver module 100% compatible with Cisco’s equivalent module ● Provides 40 Gbps throughput up to 10 kilometers (6.2 mi.) via singlemode fiber cabling ● LC duplex female connector supports 40GBase-LR4 signal at 1270-1330 nm wavelength ● Hot-swappable interface lets you install and uninstall without shutting down ● Meets or exceeds MSA standards and works in all MSAcompliant platforms MODEL NUMBER: N286-40G-LR4 Applications ● Links a singlemode Gigabit Ethernet network cable to a Cisco switch or server’s QSFP+ port. System Requirements ● Features QSFP+ Transceiver Designed for Connection to Your Cisco Network Switch or ServerThis QSFP+ transceiver allows you to connect a singlemode fiber optic cable to a 40 Gbps network router, server or switch. It transmits data up to 10 kilometers (6.2 miles) using a 1270 to 1330 nm wavelength. The zinc housing protects against electromagnetic interference (EMI) and excessive power dissipation. Functionally Equivalent to Cisco QSFP-40G-LR4 Transceiver ModuleThe MSA-compliant N286-40GLR4 functions just like the equivalent Cisco QSFP-40G-LR4 transceiver module and is manufactured to meet or exceed Cisco specifications. You can use this transceiver with any compatible Cisco router, server or switch and receive the same performance as the QSFP-40G-LR4. Hot-Swappable for Installation Without Network InterruptionThis input/output device is fully hotswappable, so you can install it without a potentially costly 40 Gbps network shutdown or device reboot. Just plug the QSFP+ end of the transceiver into your Cisco network device. The other end has an LC duplex connector to link with singlemode fiber optic cable (sold separately). A push/pull tab connector is easily accessible in high-density data center applications and makes the plug-and-play transceiver easy to install and remove with one hand. Specifications OVERVIEW UPC Code 037332248510 Brand Compatibility Cisco PHYSICAL Unit Dimensions (hwd / in.) 0.330 x 0.720 x 4.770 1/2 Install an additional LC duplex port on a Cisco router, server or switch for the purpose of connecting a singlemode Gigabit Ethernet network cable Cisco or other compatible network router, server or switch Package Includes ● N286-40G-LR4 CiscoCompatible QSFP-40G-LR4 QSFP+ Transceiver 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / cm) 0.84 x 1.83 x 12.11 Unit Dimensions (hwd / mm) 8.4 x 18.3 x 121.1 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range 32° to 158°F (0° to 70°C) Storage Temperature Range -40° to 185°F (-40° to 85°C) Relative Humidity 5% to 85% Operating Temperature 32 to 158 F (0 to 70 C) COMMUNICATIONS Network Compatibility 40 Gbps Wavelength 1270nm; 1310nm; 1330nm Transmission Distance 10 km CONNECTIONS Side A - Connector 1 LC DUPLEX (FEMALE) Side B - Connector 1 QSFP+ (MALE) FEATURES & SPECIFICATIONS Data Transfer Rate 40 Gbps Multi-Source Agreement (MSA) Compliant Yes Optical Port LC STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N286-40G-LR4 价格&库存
很抱歉,暂时无法提供与“N286-40G-LR4”相匹配的价格&库存,您可以联系我们找货
