N370X-03M
N370X-03M
    TRIPPLITE
    光纤电缆 LC 双工 至 LC 双工 9/125 9.8'(3.0m)
N370X-03M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 400G Duplex Singlemode 9/125 OS2 Switchable Fiber Optic Cable (LC/UPC M/M), LSZH, Yellow, 3 m (9.8 ft.) Highlights ● OS2-rated cable recommended for 100 Gb speeds up to 100 meters (@ 1550 nm) ● Switchable LC connectors allow polarity conversion without tools or re-termination ● Backward compatible with 10/25/40/100 Gb networks to facilitate future-proofing ● Yellow LSZH jacket allows fast, easy identification in a crowded switch or patch panel MODEL NUMBER: N370X-03M Package Includes N370X-03M 400G Duplex Singlemode 9/125 OS2 Switchable Fiber Optic Cable, Yellow, 3 m (9.8 ft.) 400 GbE Ethernet cable with switchable LC connectors supports high bandwidths necessary for enterprise applications in wiring closets, telecom rooms and data centers. Features 40/100/400 GbE Cable Supports Higher Bandwidths for High-Density Data Networking The N370X-03M is a premium multimode fiber optic cable that supports 400 Gb Ethernet speeds for transmitting data and voice signals over short distances. It is designed to support higher bandwidths for high-density patching between data center MDFs and IDFs in enterprise installations. This singlemode 9/125 OS2 cable is an ideal choice for 100 Gb Ethernet applications up to 100 meters (328 feet) at 1550 nm. It is also backward compatible with 10 Gb and 25 Gb networks, so you can future-proof your current application for an eventual upgrade to 100 Gb or 400 Gb. Switchable Connectors Allow Easy Polarity Conversions The switchable LC/UPC duplex ends let you easily switch the fiber polarity without tools or the need to reterminate the connectors. Yellow Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OS2-rated cable has a yellow jacket to identify it as singlemode in a crowded patch panel or switch and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly ventilated areas. Specifications OVERVIEW UPC Code 037332271792 Technology Singlemode Optical Mode OS2 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Mode Type Singlemode PHYSICAL Cable Jacket Color Yellow Connector Color Blue Cable Jacket Material LSZH Cable Jacket Rating OFNR Cable Outer Diameter (OD) 1.9 +/- 0.1 mm x 3.8 +/- 0.2 mm Clad Diameter (microns) 125 Core Diameter (microns) 9.0 Primary Coating Diameter (microns) 600.0 Number of Fibers 2 Cable Length (ft.) 9.8 Cable Length (m) 2.99 Cable Length (in.) 118.11 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Fiber Cable Length 3M (9.8 ft) ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Relative Humidity 5% to 85% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 40 Gbps; 100 Gbps Attenuation @ 1310NM 0.4 dB/km Attenuation @ 1550NM 0.3 dB/km Insertion Loss 0.30 dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish UPC Switchable Polarity Yes FEATURES & SPECIFICATIONS Optical Port LC 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications UL 1666 Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N370X-03M 价格&库存
很抱歉,暂时无法提供与“N370X-03M”相匹配的价格&库存,您可以联系我们找货
