1000 Eaton Boulevard
Cleveland, OH 44122
United States
400G Duplex Singlemode 9/125 OS2 Fiber Optic
Cable (CS-UPC/CS-UPC), Round LSZH Jacket,
Yellow, 10 m
Highlights
OS2-rated cable recommended
for 400 Gb speeds up to 2 km
(@ 1310 nm)
CS connectors 40% more dense
than standard LC ends for
easier cable management
Smaller-format CS ends
designed for next-generation
400G QSFP-DD transceivers
Backward compatible with
40/100 GbE networks to
facilitate future-proofing
Yellow LSZH jacket allows fast,
easy identification in a crowded
switch or patch panel
MODEL NUMBER: N381C-10M
Applications
Connect 400G fiber Ethernet
networks in your cloud service,
hyperscale data center or
telecom application
Package Includes
400 GbE Ethernet cable supports high bandwidths necessary for next-generation cloud services,
hyperscale data centers and telecom carriers.
Features
400 GbE Cable Supports Higher Bandwidths Needed for Next-Gen Data Networking
As the amount of traffic in data networks grows, so does the need for next-generation devices and fiber
cables to support much higher bandwidths in cloud services, hyperscale data centers, telecom
applications and equipment OEM companies. This duplex singlemode 9/125 OS2 cable is an ideal choice
for 400G Ethernet applications up to two kilometers (at 1310 nm). It is also backward compatible with 40
Gb and 100 Gb networks, so you can future-proof your current application for an eventual upgrade to 400
Gb.
Compact CS Connectors Designed for the Latest QSFP-DD Transceivers
The CS ends are 40 percent smaller than standard LC connectors, making them compatible with the latest
400G QSFP-DD transceivers and an excellent solution for high-density network applications. Push/pull
tabs allow dense vertical stacking in switches or patch panels where space is at a premium and make the
cable easy to install or remove with one hand.
Yellow Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OS2-rated cable has a yellow jacket, which is easy to identify quickly in a crowded patch panel or
switch and helps prevent the cable from becoming accidentally disconnected. The round low-smoke zerohalogen (LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable
for poorly ventilated areas. It also complies with G657A2 bend-insensitive fiber standards, which allows for
easy installation without excessive care when storing the fiber due to the increased bend radius.
Specifications
OVERVIEW
UPC Code
037332258014
Technology
Singlemode
1/3
N381C-10M 400Gb Duplex
Optic Cable, Yellow, 10 m
Cleveland, OH 44122
United States
Optical Mode
OS2
PHYSICAL
Cable Jacket Color
Yellow
Connector Color
Blue; White
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125
Core Diameter (microns)
9
Primary Coating Diameter (microns)
600
Number of Fibers
2
Cable Length (ft.)
32.8
Cable Length (m)
10.00
Cable Length (in.)
393.7
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
10M (32.8 ft)
ENVIRONMENTAL
Operating Temperature Range
-4° to 140°F (-20° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
400 Gbps
Transmission Distance
2KM @ 1310NM Wavelength
Attenuation @ 1310NM
0.36 dB/km
Attenuation @ 1550NM
0.22 dB/km
Insertion Loss
0.30 dB
CONNECTIONS
Side A - Connector 1
CS DUPLEX (MALE)
Side B - Connector 1
CS DUPLEX (MALE)
Endface Polish
UPC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
Yes
2/3
Cleveland, OH 44122
United States
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N381C-10M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+579.6158150+74.98216
