1000 Eaton Boulevard
Cleveland, OH 44122
United States
40/100/400G Singlemode 9/125 OS2 Fiber Optic
Cable (Duplex SN-UPC to Duplex LC-UPC M/M),
LSZH, Yellow, 3 m (9.8 ft.)
Highlights
Duplex SN connector optimized
for the latest 400 Gb
OSFP/QSFP-DD transceivers
Space-saving SN plug is 4x
smaller than duplex LC for
easier cable management
Switchable SN connector allows
polarity conversion without tools
or re-termination
Backward compatible with
40/100 Gb networks to facilitate
future-proofing
Yellow LSZH jacket allows fast,
easy identification in a crowded
switch or patch panel
MODEL NUMBER: N383L-03M
Package Includes
N383L-03M 40/100/400G
Cable, Yellow, 3 m (9.8 ft.)
40/100/400 GbE Ethernet cable supports high bandwidths necessary for next-gen cloud services,
hyperscale data centers and telecom carriers.
Features
40/100/400 GbE Cable Supports High Bandwidths for High-Density Data Networking
The N383L-03M is a premium singlemode fiber optic cable that supports 400 Gb Ethernet speeds for
transmitting data and voice signals. Its high bandwidth is ideal for hyperscale, edge, enterprise and
colocation data center interconnect (DCI) applications where density and speed are both very important.
This OS2 cable is also backward compatible with 40 Gb and 100 Gb networks, so you can future-proof
your current application for an eventual upgrade to 400 Gb.
Compact SN Connector Designed for the Latest OSFP/QSFP-DD Transceivers
One cable end features an SN connector, which is four times smaller than the standard duplex LC
connector on the other end. The SN connector provides individual and independent duplex fiber support
for an OSFP/QSFP-DD transceiver. The push/pull boot encourages dense vertical stacking within a
crowded patch panel or switch and makes the cable easy to install or remove with just one hand. The
switchable SN/UPC duplex end lets you make quick polarity changes in the field without tools or the need
to re-terminate the connectors.
Yellow-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OS2-rated cable has a yellow jacket to identify it as singlemode in a crowded patch panel or switch
and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH)
jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly
ventilated areas.
Specifications
OVERVIEW
UPC Code
037332274489
Technology
Fiber; Singlemode
1/3
Cleveland, OH 44122
United States
Optical Mode
OS2
Mode Type
Singlemode
PHYSICAL
Cable Jacket Color
Yellow
Connector Color
Blue; White
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Cable Outer Diameter (OD)
1.60 mm
Clad Diameter (microns)
125.0
Core Diameter (microns)
9.0
Primary Coating Diameter (microns)
245.0
Number of Fibers
2
Cable Length (ft.)
9.8
Cable Length (m)
2.99
Cable Length (in.)
118.1
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
3M (9.8 ft)
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps
Wavelength
1310nm; 1550nm
Attenuation @ 1310NM
0.40 dB/km
Attenuation @ 1550NM
0.30 dB/km
Insertion Loss
0.30 dB
CONNECTIONS
Side A - Connector 1
SN DUPLEX (MALE)
Side B - Connector 1
LC DUPLEX (MALE)
Endface Polish
UPC
Switchable Polarity
Yes
2/3
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
Optical Port
LC; SN
STANDARDS & COMPLIANCE
Product Certifications
UL 1651
Product Compliance
RoHS; CE (Europe); REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N383L-03M”相匹配的价格&库存,您可以联系我们找货
