1000 Eaton Boulevard
Cleveland, OH 44122
United States
400G Singlemode 9/125 OS2 Fiber Optic Cable
(Duplex SN-UPC M/M), LSZH, Yellow, 5 m (16.4
ft.)
Highlights
Duplex SN connectors
optimized for the latest 400 Gb
OSFP/QSFP-DD transceivers
Space-saving SN plugs are 4x
smaller than standard LC for
easier cable management
Switchable connectors permit
polarity conversion without tools
or re-termination
Compact push/pull boots allow
easy installation/removal with
just one hand
Yellow LSZH jacket allows fast
identification in a crowded
switch or patch panel
MODEL NUMBER: N383S-05M
Package Includes
N383S-05M 400G Singlemode
9/125 OS2 Fiber Cable, Yellow, 5
m (16.4 ft.)
400 GbE Ethernet cable supports high bandwidths necessary for next-gen hyperscale, edge, enterprise
and colocation DCI applications.
Features
400 GbE Cable Supports High Bandwidths for High-Density Data Networking
The N383S-05M is a premium singlemode fiber optic cable that supports 400 Gb Ethernet speeds for
transmitting data and voice signals. Its high bandwidth is ideal for hyperscale, edge, enterprise and
colocation data center interconnect (DCI) applications where density and speed are both very important.
Compact SN Connectors Designed for the Latest OSFP/QSFP-DD Transceivers
This 400 Gb cable features duplex SN connectors on both ends. SN connectors are four times smaller
than standard LC connectors and provide individual and independent duplex fiber support for
OSFP/QSFP-DD transceivers. Push/pull boots encourage dense vertical stacking within a crowded patch
panel or switch and make the cable easy to install or remove with just one hand. The switchable SN/UPC
ends let you make quick polarity changes in the field without tools or the need to re-terminate the
connectors.
Yellow-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OS2-rated cable has a yellow jacket to identify it as singlemode in a crowded patch panel or switch
and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH)
jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly
ventilated areas.
Specifications
OVERVIEW
UPC Code
037332274458
Technology
Fiber; Singlemode
Optical Mode
OS2
1/3
Cleveland, OH 44122
United States
Mode Type
Singlemode
PHYSICAL
Cable Jacket Color
Yellow
Connector Color
Blue; White
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Cable Outer Diameter (OD)
1.60 mm
Clad Diameter (microns)
125.0
Core Diameter (microns)
9.0
Primary Coating Diameter (microns)
245.0
Number of Fibers
2
Cable Length (ft.)
16.4
Cable Length (m)
5.00
Cable Length (in.)
196.9
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
5M (16.4 ft)
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
400 Gbps
Wavelength
1310nm; 1550nm
Attenuation @ 1310NM
0.40 dB/km
Attenuation @ 1550NM
0.30 dB/km
Insertion Loss
< 0.30 dB
CONNECTIONS
Side A - Connector 1
SN DUPLEX (MALE)
Side B - Connector 1
SN DUPLEX (MALE)
Endface Polish
UPC
Switchable Polarity
Yes
2/3
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
Optical Port
SN
STANDARDS & COMPLIANCE
Product Certifications
UL 1651
Product Compliance
RoHS; CE (Europe); REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N383S-05M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1854.609961+240.39276
