1000 Eaton Boulevard
Cleveland, OH 44122
United States
40/100/400G Singlemode 9/125 OS2 Breakout
Fiber Optic Cable (12F MTP/MPO-APC to 4x
Duplex SN-UPC F/M), LSZH, Yellow, 1 m (3.3 ft.)
Highlights
Duplex SN connector optimized
for the latest 400 Gb
OSFP/QSFP-DD transceivers
Space-saving SN plug is 4x
smaller than duplex LC for
easier cable management
MTP/MPO APC connector
minimizes back reflection with
low insertion loss
Backward compatible with
40/100 Gb networks to facilitate
future-proofing
Yellow LSZH jacket allows fast,
easy identification in a crowded
switch or patch panel
MODEL NUMBER: N390-01M-4S-AP
Package Includes
N390-01M-4S-AP 40/100/400G
Singlemode 9/125 OS2 Fiber
Cable, Yellow, 1 m (3.3 ft.)
40/100/400 GbE Ethernet cable supports high bandwidths necessary for next-gen cloud services,
hyperscale data centers and telecom carriers.
Features
40/100/400 GbE Cable Supports High Bandwidths for High-Density Data Networking
The N390-01M-4S-AP is a premium singlemode fiber optic cable that supports 400 Gb Ethernet speeds
for transmitting data and voice signals over short distances. As the amount of traffic in data networks
grows, so does the need for next-generation devices and fiber cables to support much higher bandwidths
in cloud services, hyperscale data centers, telecom applications and equipment OEM companies. This
OS2 breakout cable is an ideal choice for 400 Gb Ethernet applications. It is also backward compatible
with 40 Gb and 100 Gb networks, so you can future-proof your current application for an eventual upgrade
to 400 Gb.
Compact SN Connector Designed for the Latest OSFP/QSFP-DD Transceivers
One cable end features SN connectors, which are four times smaller than a standard duplex LC connector
and provide individual and independent duplex fiber breakout at a quad-style OSFP/QSFP-DD
transceiver. Its push/pull boot encourages dense vertical stacking within a crowded patch panel or switch
and makes the cable easy to install or remove with just one hand. Switchable SN/UPC duplex ends let
you make quick polarity changes in the field without tools or the need to re-terminate the connectors.
100% Tested for Low Insertion Loss and Back Reflection
The 12-fiber MTP/MPO APC connector with a green housing helps minimize back reflection with low
insertion loss. The connector’s slim boot is designed for easy cable management.
Yellow-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OS2-rated cable has a yellow jacket to identify it as singlemode in a crowded patch panel or switch
and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH)
jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly
ventilated areas.
Specifications
1/3
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332274526
Technology
Singlemode
Optical Mode
OS2
Mode Type
Singlemode
PHYSICAL
Cable Jacket Color
Yellow
Connector Color
Black; Blue; Green; White
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Cable Outer Diameter (OD)
3.0 mm
Clad Diameter (microns)
125.0
Core Diameter (microns)
9.0
Primary Coating Diameter (microns)
245.0
Number of Fibers
12
Cable Length (ft.)
3.3
Cable Length (m)
1.01
Cable Length (in.)
39.4
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
1M (3.3 ft)
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
40 Gbps; 100 Gbps; 400 Gbps
Wavelength
1310nm; 1550nm
Attenuation @ 1310NM
0.40 dB/km
Attenuation @ 1550NM
0.30 dB/km
Insertion Loss
MTP/MPO: < 0.70 dB; SN: < 0.30 dB
CONNECTIONS
2/3
Cleveland, OH 44122
United States
Side A - Connector 1
12-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
(4) SN DUPLEX (MALE)
Endface Polish
APC; UPC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
Yes
Optical Port
MPO/MTP; SN
STANDARDS & COMPLIANCE
Product Certifications
UL 1651
Product Compliance
RoHS; CE (Europe); REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N390-01M-4S-AP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2415.983491+312.56275
- 10+2143.4533210+277.30474
- 25+2056.7720625+266.09054
