N390-03M-8S-AP
N390-03M-8S-AP
    TRIPPLITE
    光纤电缆 MPO 至 S-PC 双工(8) 9/125 9.8'(3.0m)
N390-03M-8S-AP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 40/100/400G Singlemode 9/125 OS2 Breakout Fiber Optic Cable (16F MTP/MPO-APC to 8x Duplex SN-UPC F/M), LSZH, Yellow, 3 m (9.8 ft.) Highlights ● Duplex SN connector optimized for the latest 400 Gb OSFP/QSFP-DD transceivers ● Space-saving SN plug is 4x smaller than duplex LC for easier cable management ● MTP/MPO APC connector minimizes back reflection with low insertion loss ● Backward compatible with 40/100 Gb networks to facilitate future-proofing ● Yellow LSZH jacket allows fast, easy identification in a crowded switch or patch panel MODEL NUMBER: N390-03M-8S-AP Package Includes N390-03M-8S-AP 40/100/400G Singlemode 9/125 OS2 Fiber Cable, Yellow, 3 m (9.8 ft.) 40/100/400 GbE Ethernet cable supports high bandwidths necessary for next-gen cloud services, hyperscale data centers and telecom carriers. Features 40/100/400 GbE Cable Supports High Bandwidths for High-Density Data Networking The N390-03M-8S-AP is a premium singlemode fiber optic cable that supports 400 Gb Ethernet speeds for transmitting data and voice signals over short distances. As the amount of traffic in data networks grows, so does the need for next-generation devices and fiber cables to support much higher bandwidths in cloud services, hyperscale data centers, telecom applications and equipment OEM companies. This OS2 breakout cable is an ideal choice for 400 Gb Ethernet applications. It is also backward compatible with 40 Gb and 100 Gb networks, so you can future-proof your current application for an eventual upgrade to 400 Gb. Compact SN Connector Designed for the Latest OSFP/QSFP-DD Transceivers One cable end features SN connectors, which are four times smaller than a standard duplex LC connector and provide individual and independent duplex fiber breakout at a quad-style OSFP/QSFP-DD transceiver. Its push/pull boot encourages dense vertical stacking within a crowded patch panel or switch and makes the cable easy to install or remove with just one hand. Switchable SN/UPC duplex ends let you make quick polarity changes in the field without tools or the need to re-terminate the connectors. 100% Tested for Low Insertion Loss and Back Reflection The 16-fiber MTP/MPO APC connector helps minimize back reflection with low insertion loss. The connector’s slim boot is designed for easy cable management. Yellow-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OS2-rated cable has a yellow jacket to identify it as singlemode in a crowded patch panel or switch and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly ventilated areas. Specifications 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332274540 Technology Singlemode Optical Mode OS2 Mode Type Singlemode PHYSICAL Cable Jacket Color Yellow Connector Color Black; Blue; Green; White Cable Jacket Material LSZH Cable Jacket Rating OFNR Cable Outer Diameter (OD) 3.0 mm Clad Diameter (microns) 125.0 Core Diameter (microns) 9.0 Primary Coating Diameter (microns) 245.0 Number of Fibers 16 Cable Length (ft.) 9.8 Cable Length (m) 2.99 Cable Length (in.) 118.1 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Fiber Cable Length 3M (9.8 ft) ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range 14° to 140°F (-10° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Network Compatibility 40 Gbps; 100 Gbps; 400 Gbps Wavelength 1310nm; 1550nm Attenuation @ 1310NM 0.40 dB/km Attenuation @ 1550NM 0.30 dB/km Insertion Loss MTP/MPO: < 0.70 dB; SN: < 0.30 dB CONNECTIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side A - Connector 1 16-STRAND MTP/MPO (FEMALE) Side B - Connector 1 (8) SN DUPLEX (MALE) Endface Polish APC; UPC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout Yes Optical Port MPO/MTP; SN STANDARDS & COMPLIANCE Product Certifications UL 1651 Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N390-03M-8S-AP 价格&库存
很抱歉,暂时无法提供与“N390-03M-8S-AP”相匹配的价格&库存,您可以联系我们找货
