1000 Eaton Boulevard
Cleveland, OH 44122
United States
40/100G Singlemode 9/125 OS2 Fiber Optic Cable
(12F MTP/MPO-APC F/F), LSZH, Yellow, 7 m (23
ft.)
Highlights
OS2-rated cable recommended
for 100 Gb speeds up to 100
meters (@ 1550 nm)
MTP/MPO APC connectors
minimize back reflection with
low insertion loss
Backward compatible with
10/25/40 Gb networks to
facilitate future-proofing
Yellow LSZH jacket allows fast,
easy ID in a crowded switch or
patch panel
MODEL NUMBER: N390B-07M-12-AP
Package Includes
N390B-07M-12-AP 40/100G
Cable, Yellow, 7 m (23 ft.)
40/100 GbE Ethernet cable supports high bandwidths necessary for enterprise applications in wiring
closets, telecom rooms and data centers.
Features
100 GbE Cable Supports Higher Bandwidths Needed for Data Networking
As the amount of traffic in data networks grows, so does the need for devices and fiber cables to support
higher bandwidths in enterprise applications in wiring closets, telecom rooms and data centers. This
singlemode 9/125 OS2 cable is an ideal choice for 100G Ethernet applications up to 100 meters (328 feet)
at 1550 nm. It is also backward compatible with 10 Gb, 25 Gb and 40 Gb networks, so you can futureproof your current application for an eventual upgrade to 100 Gb.
100% Tested for Low Insertion Loss and Back Reflection
The 12-fiber MTP/MPO APC connectors with green housings help minimize back reflection with low
insertion loss.
Yellow Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OS2-rated cable has a yellow jacket to identify it as singlemode in a crowded patch panel or switch
and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH)
jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly
ventilated areas.
Specifications
OVERVIEW
UPC Code
037332272119
Technology
Fiber; Singlemode
Optical Mode
OS2
1/3
Cleveland, OH 44122
United States
PHYSICAL
Cable Jacket Color
Yellow
Connector Color
Black
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125.0
Core Diameter (microns)
9.0
Primary Coating Diameter (microns)
245.0
Number of Fibers
2
Cable Length (ft.)
23
Cable Length (m)
7.01
Cable Length (in.)
275.5
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
7M (23 ft)
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
Relative Humidity
5% to 85% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
100 Gbps; 40 Gbps; 400 Gbps
Wavelength
1310nm; 1550nm
Attenuation @ 1310NM
0.40 dB/km
Attenuation @ 1550NM
0.30 dB/km
Insertion Loss
0.70 dB
CONNECTIONS
Side A - Connector 1
12-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
Endface Polish
APC
FEATURES & SPECIFICATIONS
Optical Port
MPO/MTP
STANDARDS & COMPLIANCE
2/3
Cleveland, OH 44122
United States
Product Certifications
UL 1666
Product Compliance
RoHS; CE (Europe); REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N390B-07M-12-AP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1940.953181+251.11411
- 10+1650.0279310+213.47516
- 25+1546.8606625+200.12772
- 50+1504.8110150+194.68748
