1000 Eaton Boulevard
Cleveland, OH 44122
United States
400G Singlemode 9/125 OS2 Switchable Fiber
Optic Cable (12F MTP/MPO-APC to 4x Duplex
LC/UPC F/M), LSZH, Yellow, 3 m (9.8 ft.)
Highlights
Switchable LC connectors allow
polarity conversion without tools
or re-termination
MTP/MPO APC connector
minimizes back reflection with
low insertion loss
Backward compatible with
10/25/40 Gb networks to
facilitate future-proofing
Yellow LSZH jacket allows fast,
easy identification in a crowded
switch or patch panel
MODEL NUMBER: N390X-03M-8L-AP
Package Includes
N390X-03M-8L-AP 400G
Fiber Optic Cable, Yellow, 3 m (9.8
ft.)
400 GbE Ethernet breakout cable supports high bandwidths necessary for enterprise applications in wiring
closets, telecom rooms and data centers.
Features
40/100/400 GbE Cable Supports Higher Bandwidths for High-Density Data Networking
The N390X-03M-8L-AP is a premium multimode fiber optic cable that supports 400 Gb Ethernet speeds
for transmitting data and voice signals over short distances. It is designed to support higher bandwidths
for high-density patching between data center MDFs and IDFs in enterprise installations. This singlemode
9/125 OS2 cable is an ideal choice for 100 Gb Ethernet applications up to 100 meters (328 feet) at 1550
nm. The breakout cable also eliminates the need for long fan-out cables or long individual duplex cable
runs.
Switchable Connectors Allow Easy Polarity Conversions
The switchable LC/UPC duplex ends let you easily switch the fiber polarity without tools or the need to reterminate the connectors.
100% Tested for Low Insertion Loss and Back Reflection
The 12-fiber MTP/MPO APC connector with a green housing helps minimize back reflection with low
insertion loss. The connector’s slim boot is designed for easy cable management.
Yellow Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OS2-rated cable has a yellow jacket to identify it as singlemode in a crowded patch panel or switch
and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH)
jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly
ventilated areas.
Specifications
OVERVIEW
UPC Code
037332272393
1/3
Cleveland, OH 44122
United States
Technology
Singlemode
Optical Mode
OS2
PHYSICAL
Cable Jacket Color
Yellow
Connector Color
Blue; Green; Black
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125.0
Core Diameter (microns)
9.0
Primary Coating Diameter (microns)
245.0
Number of Fibers
2
Cable Length (ft.)
9.8
Cable Length (m)
2.99
Cable Length (in.)
118.1
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
3M (9.8 ft)
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
Relative Humidity
5% to 85% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
10 Gbps; 40 Gbps; 100 Gbps; 400 Gbps
Wavelength
1310nm; 1550nm
Attenuation @ 1310NM
0.40 dB/km
Attenuation @ 1550NM
0.30 dB/km
Insertion Loss
0.70 dB
CONNECTIONS
Side A - Connector 1
12-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
(4) LC DUPLEX (MALE)
Endface Polish
APC; UPC
Switchable Polarity
Yes
FEATURES & SPECIFICATIONS
2/3
Cleveland, OH 44122
United States
Push/Pull Tabs
Yes
Breakout
Yes
Optical Port
MPO/MTP
STANDARDS & COMPLIANCE
Product Certifications
UL 1666
Product Compliance
RoHS; CE (Europe); REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N390X-03M-8L-AP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1695.821601+220.14521
