N48M-48M8L4-05
N48M-48M8L4-05
    TRIPPLITE
    PRELOADED FIBER PATCH PANEL, 3U
N48M-48M8L4-05 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Preloaded Fiber Patch Panel, 3U - 48x (12F MTP/MPO-PC to 4x LC Duplex F/F) 8F Trunk Cables, OM4 Multimode, 5 m (16.4 ft.) Highlights ● 48 MTP/MPO-to-LC 8-fiber OM4 multimode cables come coiled inside for instant use ● Use only as much cable as you need; store the remainder inside to avoid clutter ● Flexible cable length allows reuse of cables if equipment is moved ● 192 LC Duplex ports protected by fold-down front panel with organization labels ● Aluminum chassis mounts into 3U of space in EIA-standard 19 in. racks MODEL NUMBER: N48M-48M8L4-05 Applications 3U patch panel comes preloaded with spools of multimode fiber cable that allow you to extend the exact length required and store the excess out of sight. ● Integrate 10G equipment with a 40G network or 25G equipment with a 100G network ● Save the expense and effort of buying custom cables or repurchasing cables after moving rack equipment ● Eliminate cable clutter by using only as much as you need and storing excess cable inside the panel Description Preloaded Fiber Patch Panel, 3U - 48x (12F MTP/MPO-PC to 4x LC Duplex F/F) 8F Trunk Cables, OM4 Multimode, 5 m (16.4 ft.) Package Includes Features 3U Panel Solution Comes with Cabling Preloaded to Cut Costs and Save Time All necessary cabling is included with this preloaded fiber panel, coiled inside and ready for immediate use. The aluminum 3U chassis features 48 MTP/MPO-PC to LC Duplex 8-fiber multimode trunk cables, all five meters (16.4 feet) in length to make management easy. The panel opens to provide easy access to stored cables. Use only as much cabling as you need. The remainder stores inside the chassis to eliminate cable clutter, allow better airflow through the rack and make equipment maintenance and replacement easier. The cables and panels have labels to help with organization. You also avoid the expense and effort of custom cabling. The flexibility in cable length lets you reuse the cables if equipment is moved. Integrates Equipment to Meet Current Connectivity Needs This preloaded slack-free panel helps integrate your 10 Gb equipment with 40 Gb networks or 25 Gb equipment with 100 Gb networks in a simple, elegant and flexible manner. The N48M-48M8L4-05 mounts in just 3U of space in an EIA-standard 19-inch rack. Specifications OVERVIEW UPC Code 037332262240 Product Type Preloaded Technology Multimode 1/3 ● N48M-48M8L4-05 Preloaded Fiber Patch Panel ● (48) MTP/MPO-PC to LC Duplex trunk cables, 5 m (16.4 ft.) ● Installation guide 1000 Eaton Boulevard Cleveland, OH 44122 United States Optical Mode OM4 Panel Dimensions 17.42" X 5.24" X 12.99" Panel Cable Number 48 Panel Cable Length (m) 5 Fiber Panel Ports (192) LC Duplex; (48) MTP/MPO Mode Type Multimode Firmware / Software Docs Offset Ports No PHYSICAL Primary Form Factor Rackmount Rack Height 3U Cable Jacket Color Aqua Cable Jacket Rating OFNP Cable Outer Diameter (OD) 2.9 mm Clad Diameter (microns) 125 Core Diameter (microns) 50 Primary Coating Diameter (microns) 245 Number of Fibers 8 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Shipping Dimensions (hwd / in.) 8.90 x 22.00 x 18.90 Shipping Weight (lbs.) 19.18 Shipping Weight (kg) 8.70 Fiber Cable Length 5M (16.4 ft) ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Network Compatibility 40 Gbps; 100 Gbps; 400 Gbps 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Wavelength 1300nm; 850nm Attenuation @ 850NM 3.0 dB / km Attenuation @ 1300NM 1.0 dB / km Insertion Loss MTP/MPO: 0.35 dB; LC: 0.20 dB CONNECTIONS Side A - Connector 1 (48) MTP/MPO (FEMALE) Side B - Connector 1 (192) LC DUPLEX (FEMALE) Endface Polish PC FEATURES & SPECIFICATIONS All-in-One Kit Yes Push/Pull Tabs Yes Numbered Ports Yes Built-in Cables Yes Optical Port LC; MPO/MTP STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N48M-48M8L4-05 价格&库存
很抱歉,暂时无法提供与“N48M-48M8L4-05”相匹配的价格&库存,您可以联系我们找货
