1000 Eaton Boulevard
Cleveland, OH 44122
United States
Preloaded Fiber Panel, 1U - 4x (8x LC/LC Duplex
M/M) 16F Trunk Cables, OM4 Multimode, 10 m
(32.8 ft.)
Highlights
4 LC Duplex 16-fiber OM4
multimode cables come coiled
inside for instant use
Use only as much cable as you
need; store the remainder inside
to avoid clutter
Flexible cable length allows
reuse of cables if equipment is
moved
Aluminum chassis mounts into
1U of space in EIA-standard 19
in. racks
MODEL NUMBER: N48M-4L16L-10
Applications
1U panel comes preloaded with spools of multimode fiber cable that allow you to extend the exact length
required and store the excess out of sight.
Description
Preloaded Fiber Panel, 1U - 4x (8x LC/LC Duplex M/M) 16F Trunk Cables, OM4 Multimode, 10 m (32.8
ft.)
Features
1U Panel Solution Comes with Cabling Preloaded to Cut Costs and Save Time
All necessary cabling is included with this preloaded fiber panel, coiled inside and ready for immediate
use. The aluminum 1U chassis features four 16-fiber LC Duplex multimode trunk cables, all 10 meters
(32.8 feet) in length to make management easy. The panel opens to provide easy access to stored
cables. Use only as much cabling as you need. The remainder stores inside the chassis to eliminate cable
clutter, allow better airflow through the rack and make equipment maintenance and replacement easier.
The cables and panels have labels to help with organization. You also avoid the expense and effort of
custom cabling. The flexibility in cable length lets you reuse the cables if equipment is moved. The N48M4L16L-10 mounts in just 1U of space in an EIA-standard 19-inch rack.
Specifications
OVERVIEW
UPC Code
037332262097
Product Type
Preloaded
Technology
Multimode
Optical Mode
OM4
Panel Dimensions
17.32" X 1.73" X 10.20"
Panel Cable Number
4
1/3
Save the expense and effort of
buying custom cables or
repurchasing cables after
moving rack equipment
Eliminate cable clutter by using
only as much as you need and
storing excess cable inside the
panel
Package Includes
N48M-4L16L-10 Preloaded
Fiber Panel
(4) LC Duplex to LC Duplex
trunk cables, 10 m (32.8 ft.)
Installation guide
Cleveland, OH 44122
United States
Panel Cable Length (m)
10
Mode Type
Multimode
Firmware / Software Docs
Offset Ports
No
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
1U
Cable Jacket Color
Aqua
Connector Color
Aqua; White
Cable Jacket Rating
OFNP
Cable Outer Diameter (OD)
2.9 mm
Clad Diameter (microns)
125
Core Diameter (microns)
50
Primary Coating Diameter (microns)
245
Number of Fibers
16
Cable Length (ft.)
32.8
Cable Length (m)
10.00
Cable Length (in.)
393.7
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Shipping Dimensions (hwd / in.)
4.30 x 22.80 x 18.90
Shipping Weight (lbs.)
8.16
Shipping Weight (kg)
3.70
Fiber Cable Length
10M (32.8 ft)
ENVIRONMENTAL
Operating Temperature Range
-4° to 140°F (-20° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps
Wavelength
1300nm; 850nm
Attenuation @ 850NM
3.0 dB / km
Attenuation @ 1300NM
1.0 dB / km
2/3
Cleveland, OH 44122
United States
Insertion Loss
0.20 dB
CONNECTIONS
Side A - Connector 1
(8) LC DUPLEX (MALE)
Side B - Connector 1
Endface Polish
PC
FEATURES & SPECIFICATIONS
All-in-One Kit
Yes
Built-in Cables
Yes
Optical Port
LC
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N48M-4L16L-10”相匹配的价格&库存,您可以联系我们找货
