1000 Eaton Boulevard
Cleveland, OH 44122
United States
Preloaded Fiber Panel, 1U - 2x (3x8F MTP/MPOAPC F/F) 24F Trunk Cables, OS2 Singlemode, 20
m (65.6 ft.)
Highlights
Dual MTP/MPO-APC 24-fiber
OS2 singlemode cables come
coiled inside for instant use
Use only as much cable as you
need; store the remainder inside
to avoid clutter
Flexible cable length allows
reuse of cables if equipment is
moved
Aluminum chassis mounts into
1U of space in EIA-standard 19
in. racks
MODEL NUMBER: N48S-2M3X8M-20
Applications
1U panel comes preloaded with spools of singlemode fiber cable that allow you to extend the exact length
required and store the excess out of sight.
Description
Save the expense and effort of
buying custom cables or
repurchasing cables after
moving rack equipment
Eliminate cable clutter by using
only as much as you need and
storing excess cable inside the
panel
Package Includes
N48S-2M3X8M-20 Preloaded
Fiber Panel
(2) MTP/MPO-APC to
MTP/MPO-APC trunk cables, 20
m (65.6 ft.)
Installation guide
Preloaded Fiber Panel, 1U - 2x (3x8F MTP/MPO-APC F/F) 24F Trunk Cables, OS2 Singlemode, 20 m
(65.6 ft.)
Features
1U Panel Solution Comes with Cabling Preloaded to Cut Costs and Save Time
All necessary cabling is included with this preloaded fiber panel, coiled inside and ready for immediate
use. The aluminum 1U chassis features two 24-fiber MTP/MPO-APC singlemode trunk cables, both 20
meters (65.6 feet) in length to make management easy. The panel opens to provide easy access to stored
cables. Use only as much cabling as you need. The remainder stores inside the chassis to eliminate cable
clutter, allow better airflow through the rack and make equipment maintenance and replacement easier.
The cables and panels have labels to help with organization. You also avoid the expense and effort of
custom cabling. The flexibility in cable length lets you reuse the cables if equipment is moved. The N48S2M3X8M-20 mounts in just 1U of space in an EIA-standard 19-inch rack.
Specifications
OVERVIEW
UPC Code
037332262714
Product Type
Preloaded
Technology
Singlemode
Optical Mode
OS2; SM
Panel Dimensions
17.32" X 1.73" X 10.20"
Panel Cable Number
2
1/3
Cleveland, OH 44122
United States
Panel Cable Length (m)
Mode Type
Singlemode
Firmware / Software Docs
Offset Ports
No
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
1U
Cable Jacket Color
Yellow
Connector Color
Black; Green
Cable Jacket Material
PVC
Cable Jacket Rating
OFNP
Cable Outer Diameter (OD)
2.9 mm
Clad Diameter (microns)
125
Core Diameter (microns)
9
Primary Coating Diameter (microns)
245
Number of Fibers
24
Cable Length (ft.)
65.6
Cable Length (m)
20.00
Cable Length (in.)
787.4
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Shipping Dimensions (hwd / in.)
4.30 x 22.80 x 18.90
Shipping Weight (kg)
3.50
Fiber Cable Length
20M (65.6 ft)
ENVIRONMENTAL
Operating Temperature Range
-4° to 140°F (-20° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
40 Gbps; 100 Gbps; 400 Gbps
Wavelength
1310nm; 1550nm
Attenuation @ 1310NM
0.36 dB / km
Attenuation @ 1550NM
0.22 dB / km
2/3
Cleveland, OH 44122
United States
Insertion Loss
0.30 dB
CONNECTIONS
Side A - Connector 1
(3) MTP/MPO (FEMALE)
Side B - Connector 1
Endface Polish
APC
FEATURES & SPECIFICATIONS
All-in-One Kit
Yes
Push/Pull Tabs
Yes
Built-in Cables
Yes
Optical Port
MPO/MTP
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N48S-2M3X8M-20”相匹配的价格&库存,您可以联系我们找货
