N784-H01-STMM
N784-H01-STMM
    TRIPPLITE
    HARDENED COPPER TO FIBER MEDIA C
N784-H01-STMM 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Hardened Copper to Fiber Media Converter 10/100 Mbps, RJ45/ST Multimode, -10° to 60°C, 2 km (1.2 mi.) Highlights ● Extends up to 100 Mbps of data to a network device located up to 2 km away ● Automatic MDI/MDI-X configuration connects devices without crossover cabling ● Hardened aluminum housing withstands operating temperature range of -10° to 60°C ● LEDs indicate Ethernet connection and various statuses, including data transfer speed ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: N784-H01-STMM Package Includes Extends a 10/100 Mbps Ethernet network connection over ST duplex multimode fiber optic cable up to 2 kilometers. ● N784-H01-STMM Media Converter ● L-shaped bracket ● Rubber foot ● ST connector cap ● External power supply with NEMA 1-15P plug (Input: 100–240VAC, 50/60 Hz, 0.5A; Output: 12VDC 1.5A) ● DIN rail kit ● Wall-mounting hardware ● Quick Start Guide Features Extends a Network Connection up to 2 km over ST Multimode Fiber Optic Cable This network media converter converts a copper Ethernet signal to a multimode fiber optic signal and extends it to a second network device up to two kilometers (1.2 miles) away. Because copper Cat5e/6 cables are limited to only 100 meters, it is more effective to couple the N784-H01-STMM with multimode fiber cable to reach hubs, switches and other 10/100Base-TX/FX network devices located farther away. Auto-negotiation and automatic MDI/MDI-X configuration seamlessly connect devices without crossover cabling. Monitor Your Installation with Link Fault Signaling and Loop Back Functions Determine the health of your network connection via the Link Fault Signaling (LFS) and Loop Back functions. The LFS LED indicates when a copper or fiber cable has been severed or another cause of disruption in service has occurred. The Local Loop Back (LLB) and Remote Loop Back (RLB) functions ensure copper and fiber cables have been correctly installed. Use the DIP switches to control each function or turn them on or off. LEDs Indicate Installation Performance and Diagnostic Functions Easy-to-read LEDs on the side of the unit indicate essential status information, including network speed and connection, LFS diagnostics and unit power. Protective Metal Housing Built to Withstand a Variety of Hazards The hardened aluminum case is designed to operate in extreme temperatures ranging from -10 to 60 degrees Celsius (14 to 140 degrees Fahrenheit). It is protected from electrostatic discharge (ESD), radio frequency interference (RFI) and power surges. Hardware is included for wall or DIN mounting. Works in Tandem with N785-CH12 Chassis House and power up to 12 media converters, including the N784-H01-STMM, using the N785-CH12 12port chassis (sold separately) to create an organized installation. TAA-Compliant for GSA Schedule Purchases The N784-H01-STMM is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332267023 Product Type Fiber to Ethernet Technology Cat5/5e; Cat6; Multimode Mode Type Multimode DISPLAY Accessories (Included) External Power Supply (Input: 100-240V, 50/60Hz, 0.5A; Output: 12V/1.5A), Mounting Bracket, Mounting Hardware, DIN Rail, ST Connector Cap, L-Shape Holder, Rubber Foot NETWORK Network Ports RJ45 (FEMALE); ST (FEMALE) INPUT AC Power Adapter Plug(s) NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A AC Power Adapter Output Specs (V / A) 12V / 1.5A AC Power Adapter Cord Length (ft.) 3.94 AC Power Adapter Cord Length (m) 1.2 Nominal Input Voltage(s) Supported 120V AC; 240V AC POWER Power Source Type AC Adapter AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 12V, 1.5A DC Barrel Plug OD: 5.5 x 2.5 x 11mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 1.80 USER INTERFACE, ALERTS & CONTROLS LED Indicators PWR = Green (Power); ALM = Red (LFS Alarm); 100 (Green) = Fiber 100 Mbps Ethernet; LNK/ACT (Green) = Fiber data transmitting/receiving; 100 (Green) = RJ45 10/100 Mbps; LNK/ACT (Green) = Copper data transmitting/receiving PHYSICAL Color Black Power Cord Color Black Unit Dimensions (hwd / in.) 0.920 x 2.910 x 4.300 Unit Dimensions (hwd / cm) 2.34 x 7.38 x 10.92 Unit Packaging Type Box 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (lbs.) 0.5267 Unit Weight (kg) 0.24 Housing Metal ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -40° to 185°F (-40° to 85°C) Relative Humidity 5% to 95% RH, Non-Condensing COMMUNICATIONS Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) Network Speed Details 10 Mbps; 100 Mbps Wavelength 1310nm Transmission Distance 2 km IEEE Standards Supported 802.3; 802.3u Wavelength Division Multiplexing (WDM) Yes CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 ST (FEMALE) FEATURES & SPECIFICATIONS Data Transfer Rate 10 Mbps; 100 Mbps Mounting Accessory Included Yes Auto MDIX Support Yes DIN Mountable Yes Optical Port ST STANDARDS & COMPLIANCE External Power Supply Certifications FCC; LPS; UL; WEEE Product Compliance RoHS; CE (Europe); FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
N784-H01-STMM 价格&库存
很抱歉,暂时无法提供与“N784-H01-STMM”相匹配的价格&库存,您可以联系我们找货
