N785-H01-SFP-D
N785-H01-SFP-D
    TRIPPLITE
    HARDENED GIGABIT FIBER TO ETHERN
N785-H01-SFP-D 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Hardened Gigabit Fiber to Ethernet Media Converter, 10/100/1000 Mbps, RJ45/SFP, -10° to 60°C, DC Power Highlights ● Customizable converter extends up to 1000 Mbps (1 Gbps) of data via open SFP port ● Automatic MDI/MDI-X configuration connects devices without crossover cabling ● Hardened aluminum housing withstands operating temperature range of -10° to 60°C ● Primary and redundant power supply ports allow connection of dual DC power sources ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: N785-H01-SFP-D Package Includes Extends a 10/100/1000 Mbps Gigabit Ethernet network connection over fiber optic cable using your choice of SFP transceiver. Features Customize a Network Connection Extension over Fiber Optic Cable This network media converter works with a variety of SFP transceivers to convert a copper Gigabit Ethernet signal to fiber optic and extend it to a second network device. The customizable SFP port supports both singlemode and multimode transceivers, allowing your network connection to reach hubs, switches and other devices located farther away than copper cabling’s 100-meter limit. Auto-negotiation and automatic MDI/MDI-X configuration seamlessly connect devices without crossover cabling. Monitor Your Installation with Line Loop Back Determine the health of your network connection via the Line Loop Back (LLB) function, which ensures copper and fiber cables have been correctly installed. Use the DIP switches to control each function or turn them on or off. LEDs Indicate Installation Performance and Diagnostic Functions Easy-to-read LEDs on the side of the unit indicate essential status information, including network speed and connection, LFS diagnostics and unit power. The included 20–57VDC terminal block provides primary and secondary power inputs. Protective Metal Housing Built to Withstand a Variety of Hazards The hardened aluminum case is designed to operate in extreme temperatures ranging from -10 to 60 degrees Celsius (14 to 140 degrees Fahrenheit). It is protected from electrostatic discharge (ESD), radio frequency interference (RFI) and power surges. Hardware is included for DIN mounting. TAA-Compliant for GSA Schedule Purchases The N785-H01-SFP-D is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications 1/3 ● N785-H01-SFP-D Media Converter ● SFP connector cap ● RJ45 connector cap ● Terminal block (20–57VDC) ● DIN rail kit ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332268570 Product Type Fiber to Ethernet Technology Cat5/5e; Cat6; Fiber Mode Type Multimode; Singlemode DISPLAY Accessories (Included) RS232 Terminal Block, DIN Rail Mount, RJ45 Insert Cap, SFP Insert Cap NETWORK Network Ports RJ45 (FEMALE); SFP (FEMALE) INPUT AC Power Adapter Input Specs (V / Hz / A) 20-57V DC POWER Power Consumption (Watts) 5.50 USER INTERFACE, ALERTS & CONTROLS LED Indicators PWR (Power), RPS (Redundant power), ALM (PWR & RPS fails), SFP (For SFP port link-up), 1000 (For Ethernet speed 1000Mbps, LNK/ACT (For data transmitting/receiving) PHYSICAL Color Black Unit Dimensions (hwd / in.) 1.970 x 4.570 x 3.940 Unit Dimensions (hwd / cm) 5 x 11.6 x 10 Unit Packaging Type Box Unit Weight (lbs.) 0.93 Unit Weight (kg) 0.42 Housing Metal ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -40° to 185°F (-40° to 85°C) Operating Humidity Range 10% to 95% RH, (Non-Condensing) Storage Humidity Range 5% to 95% RH (Non-condensing) COMMUNICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet); 1 Gbps (Gigabit) Network Speed Details 10 Mbps; 100 Mbps; 1000 Mbps Transmission Distance Depends on transceiver used IEEE Standards Supported 802.3; 802.3ab; 802.3u; 802.3x; 802.3z Wavelength Division Multiplexing (WDM) Yes CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 SFP (FEMALE) FEATURES & SPECIFICATIONS Data Transfer Rate 1 Gbps; 10 Mbps; 100 Mbps Mounting Accessory Included Yes Auto MDIX Support Yes DIN Mountable Yes Optical Port SFP STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N785-H01-SFP-D 价格&库存
很抱歉,暂时无法提供与“N785-H01-SFP-D”相匹配的价格&库存,您可以联系我们找货
N785-H01-SFP-D
库存:32
