N785-H01-SFP
N785-H01-SFP
    TRIPPLITE
    HARDENED GIGABIT FIBER TO ETHERN
N785-H01-SFP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Hardened Gigabit Fiber to Ethernet Media Converter, 10/100/1000 Mbps, RJ45/SFP, -10° to 60°C Highlights ● Customizable converter extends up to 1000 Mbps (1 Gbps) of data via open SFP port ● Automatic MDI/MDI-X configuration connects devices without crossover cabling ● Hardened aluminum housing withstands operating temperature range of -10° to 60°C ● LEDs indicate Ethernet connection and various statuses, including data transfer speed ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: N785-H01-SFP Package Includes Extends a 10/100/1000 Mbps Gigabit Ethernet network connection over fiber optic cable using your choice of SFP transceiver. ● N785-H01-SFP Media Converter ● L-shaped bracket ● Rubber foot ● SFP connector cap ● External power supply with NEMA 1-15P plug (Input: 100–240VAC, 50/60 Hz, 0.5A; Output: 12VDC 1.5A) ● DIN rail kit ● Wall-mounting hardware ● Quick Start Guide Features Customize a Network Extension over Fiber Optic Cable This network media converter works with a variety of SFP transceivers to convert a copper Gigabit Ethernet signal to fiber optic and extend it to a second network device. The customizable SFP port supports both singlemode and multimode transceivers, allowing your network connection to reach hubs, switches and other devices located farther away than copper cabling’s 100-meter limit. Auto-negotiation and automatic MDI/MDI-X configuration seamlessly connect devices without crossover cabling. Monitor Your Installation with Link Fault Signaling and Loop Back Functions Determine the health of your network connection via the Link Fault Signaling (LFS) and Loop Back functions. The LFS LED indicates when a copper or fiber cable has been severed or another cause of disruption in service has occurred. The Local Loop Back (LLB) and Remote Loop Back (RLB) functions ensure copper and fiber cables have been correctly installed. Use the DIP switches to control each function or turn them on or off. LEDs Indicate Installation Performance and Diagnostic Functions Easy-to-read LEDs on the side of the unit indicate essential status information, including network speed and connection, LFS diagnostics and unit power. Protective Metal Housing Built to Withstand a Variety of Hazards The hardened aluminum case is designed to operate in extreme temperatures ranging from -10 to 60 degrees Celsius (14 to 140 degrees Fahrenheit). It is protected from electrostatic discharge (ESD), radio frequency interference (RFI) and power surges. Hardware is included for wall or DIN mounting. Works in Tandem with N785-CH12 Chassis House and power up to 12 media converters, including the N785-H01-SFP, using the N785-CH12 12-port chassis (sold separately) to create an organized installation. TAA-Compliant for GSA Schedule Purchases The N785-H01-SFP is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332268563 Product Type Fiber to Ethernet Technology Cat5/5e; Cat6; Multimode Mode Type Multimode; Singlemode DISPLAY Accessories (Included) External Power Supply (Input: 100-240V, 50/60Hz, 0.5A; Output: 12V/1.5A), Mounting Bracket, Mounting Hardware, DIN Rail, SFP Insert Cap, L-Shape Holder, Rubber Foot NETWORK Network Ports RJ45 (FEMALE); SFP (FEMALE) INPUT AC Power Adapter Plug(s) NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A AC Power Adapter Output Specs (V / A) 12V / 1.5A AC Power Adapter Cord Length (ft.) 3.94 AC Power Adapter Cord Length (m) 1.2 POWER Power Source Type AC Adapter AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 12V, 1.5A DC Barrel Plug OD: 5.5 x 2.5 x 11mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 1.80 USER INTERFACE, ALERTS & CONTROLS LED Indicators PWR (Power), ALM (LFS function indicator), Fiber - 1000 (For Ethernet speed 1000Mbps), LNK/ACT (For Fiber port data transmitting/receiving), RJ45 - 1000 (For RJ45 speed 1000Mbps), LNK/ACT (For Copper port data transmitting/rec) PHYSICAL Color Black Power Cord Color Black Unit Dimensions (hwd / in.) 0.920 x 2.910 x 4.300 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / cm) 2.34 x 7.38 x 10.92 Unit Packaging Type Box Unit Weight (lbs.) 0.5267 Unit Weight (kg) 0.24 Housing Metal ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -40° to 185°F (-40° to 85°C) Relative Humidity 5% to 95% RH, Non-Condensing COMMUNICATIONS Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet); 1 Gbps (Gigabit) Network Speed Details 10 Mbps; 100 Mbps; 1000 Mbps Transmission Distance Dependent on SFP type; RJ45 = 100 M IEEE Standards Supported 802.3; 802.3ab; 802.3u; 802.3z Wavelength Division Multiplexing (WDM) Yes CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 SFP (FEMALE) FEATURES & SPECIFICATIONS Data Transfer Rate 1 Gbps; 10 Mbps; 100 Mbps Mounting Accessory Included Yes Auto MDIX Support Yes DIN Mountable Yes Optical Port SFP STANDARDS & COMPLIANCE External Power Supply Certifications FCC; LPS; UL; WEEE Product Compliance RoHS; CE (Europe); FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
N785-H01-SFP 价格&库存
很抱歉,暂时无法提供与“N785-H01-SFP”相匹配的价格&库存,您可以联系我们找货
N785-H01-SFP
库存:315
