N785-CH12
N785-CH12
    TRIPPLITE
    网络 底座 配用 N784-H,N785-H
N785-CH12 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Highlights Important Note The N785-CH12 is compatible with both AC and DC power supplies but should never be used with one of each in the primary and redundant power supply bays. 12-Slot Media Converter Chassis for Select N784H and N785-H Models, 3U Rack Mount ● Accepts up to 12 select media converters, including SC, ST and SFP types ● Rear fans keep equipment cool and connect to front LEDs for easy troubleshooting ● Compatible with primary and redundant DC or AC power supplies (AC supply included) ● On/off trigger guard helps prevent the power switch from being activated by accident ● Flexible installation options include desktop, wall and 3U rack with included hardware MODEL NUMBER: N785-CH12 System Requirements Houses and powers up to 12 media converters to help you create customized copper-to-fiber or copperto-copper installations. ● Accommodates select N784-H and N785-H media converters, including N784-H01-SCMM, N784-H01-STMM, N784-H01SCSM, N785-H01-SCMM, N785-H01-SCSM and N785H01-SFP ● Not compatible with N785-H01SFP-D, N785-I01-SFP-D and N785-I01-SFP-DU Package Includes ● N785-CH12 3U 12-Slot Media Converter Chassis ● N785-CH75W-AC Power supply with 6 ft. power cord, NEMA 515P plug and glass-tube fuse (Input: 90–240V, 50/60 Hz, 2A; Output: 12V 6.5A) ● (2) Mounting brackets ● (24) Mounting panels ● (2) Rack-mount kits ● (48) M3 6x5 mm screws ● (10) F3 6x5 mm screws ● (6) M5 16x10 mm screws ● (4) M4 10x8 mm screws ● (2) Spare glass-tube fuses ● Owner’s manual Features House, Organize and Power Up to 12 Media Converters This media converter chassis accommodates as many as 12 N784-H and N785-H multimedia converters, including SC, ST and SFP fiber types. You can easily install the media converters in the chassis’ input slots using the included mounting brackets and hardware to create a variety of copper-to-fiber or copperto-copper installations, including singlemode, multimode and open SFP port converters. The N785-CH12 is compatible with N784-H01-SCMM, N784-H01-STMM, N784-H01-SCSM, N785-H01-SCMM, N785-H01SCSM and N785-H01-SFP converters. Works with DC and AC Power Supplies The N785-CH12 is compatible with both DC and AC power supplies, including the preinstalled N785CH75W-AC with six-foot (1.8-meter) power cord, NEMA 5-15P input and preinstalled glass-tube fuse (two spare fuses are also included). A second power supply may be installed to provide redundant power to the chassis and avoid network downtime. A trigger guard helps prevent the power switch from being turned off accidentally. Note: Only one type of power supply should be used. Do not mix DC and AC power supplies. N785-CH75W-DC power supply is sold separately. Rear Fans Help Prevent Overheating Three fans built into the rear of the chassis draw air inward to help keep the media converters cool. You may periodically clean the fans by removing the panel assembly. LEDs Keep You Informed at a Glance Green LEDs on the front Status Monitoring Panel indicate when a media converter has been correctly installed in each input slot. These LEDs will not illuminate if an input slot is empty or if power is not being properly supplied. Three red LEDs let you know the cooling fans are functioning properly. Another red LED informs you that the chassis is receiving power. 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Flexibility in Installation Gives You Options The N785-CH12 mounts into 3U of space in your EIA-standard 19-inch rack using the included hardware. It can also rest flat on any desktop or mount on a wall with the use of a shelf (not included) that is securely mounted to a suitable structure. The shelf must support at least 33 pounds (15 kilograms). It should not only be large enough to accommodate the chassis, but also allow sufficient space for adequate ventilation on all sides. Specifications OVERVIEW UPC Code 037332268600 Accessory Type Chassis Accessory Class Networking Accessories INPUT AC Power Adapter Plug(s) NEMA 5-15P North America AC Power Adapter Input Specs (V / Hz / A) 90-240V / 50/60Hz / 2A AC Power Adapter Output Specs (V / A) 12V / 6.5A AC Power Adapter Cord Length (ft.) 6 AC Power Adapter Cord Length (m) 1.83 POWER Power Source Type AC Adapter Dual Power Supply (Y/N) Yes USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs FAN 1-3 (x3); SLOT 1-12 (x12) PHYSICAL Included Mounting Accessories Mounting Bracket (x2), Mounting Panel (x24), Rack Mounting Kit (x2), M3 6x5mm Screw (x48), F3 6x5mm Screw (x10), M5 16x10mm Screw (x4) Included Mounting Accessory Description Includes x2 Mounting Brackets for mounting to a surface. Includes x2 Rack Mounting Kit handles and screws for mounting in a rack. Usable Rack Space 3U Rackmountable Yes Unit Dimensions (hwd / in.) 11.420 x 16.930 x 5.240 Unit Dimensions (hwd / cm) 29 x 43 x 13.3 Unit Packaging Type Box Rack Compatibility 600 mm (Standard) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Mounting Accessory Included Yes STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N785-CH12 价格&库存
很抱歉,暂时无法提供与“N785-CH12”相匹配的价格&库存,您可以联系我们找货
