N820-05M-IND
N820-05M-IND
    TRIPPLITE
    光纤电缆 LC 双工 至 LC 双工 50/125 16.4'(5.0m)
N820-05M-IND 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 10Gb Rigid Industrial Duplex Multimode 50/125 OM3 Fiber Patch Cable (LC/LC) - IP68, Aqua, 5 m (16.4 ft.) Highlights ● Protects 10Gb fiber Ethernet applications in outdoor or harsh environments ● Resists dust and endures immersion in 1.5 m of water up to 60 min. ● Low insertion loss of >0.10 db ensures a strong signal through your network ● Color-coded aqua for fast, easy OM3 identification in a crowded rack or patch panel MODEL NUMBER: N820-05M-IND Applications Connects fiber optic Ethernet equipment in industrial environments that require protection against dust and moisture. ● Connect 10G fiber Ethernet networks in factories, warehouses, recycling plants, machine shops and other environments prone to dust or water ● Provide connectivity in outdoor environments susceptible to rain, such as a stadium or outdoor arena Package Includes ● Features 10G Duplex Multimode Cable Designed for Outdoor or Harsh Indoor EnvironmentsThis 16.4-foot (five-meter) 50/125 OM3 LC/LC IP68-rated outdoor cable is ideal for connecting 10G Ethernet fiber networks in outdoor applications and other areas where protection from harsh elements is essential, such as factories, warehouses, recycling plants, machine shops and other dusty environments. The rigid, durable cable and small-form-factor LC duplex connectors withstand dust, debris and moisture that could threaten your IT infrastructure. Included dust caps are located at both ends for protection from dust and debris when the connectors are not in use. IP68 Rating Denotes Resistance to Dust and WaterThe fiber cable is 100% protected against dust and able to endure immersion in 1.5 meters of water for up to 60 minutes with no damage or decline in performance. Concentration of water moisture in fiber connectors will lead to glass damage and can severely disrupt or halt performance of optical cables. For applications that require IP68 protection, use the industrial cable with a N206-SB01-IND surface-mount box and an N455-BC01-IND bulkhead coupler. If only IP44 protection against splashing water from all directions is required, pair the cable with a N206FP01-IND, N206-FP02-IND or N206-FP04-IND metal wall plate and an N455-BC01-IND bulkhead coupler. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis fiber cable features an aqua PVC jacket with LC duplex ends. The color-coding allows easy, fast OM3 identification in a crowded rack, patch panel or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332252746 Technology Multimode 1/3 N820-05M-IND 10Gb Duplex Multimode 50/125 OM3 Fiber Patch Cable, Aqua, 5 m 1000 Eaton Boulevard Cleveland, OH 44122 United States Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color Beige Cable Jacket Material PVC Cable Jacket Rating OFNR Cable Outer Diameter (OD) 7.5 mm Clad Diameter (microns) 50 Core Diameter (microns) 125 Number of Fibers 2 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.850 Cable Length (cm) 500 Minimum Bend Radius 7.5 * 20=150mm Fiber Cable Length 5M (16.4 ft) ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Relative Humidity 0% to 90% RH, Non-Condensing Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Network Compatibility 10 Gbps Attenuation @ 1310NM 1.5dB/km Attenuation @ 850NM 3.5 dB/km Insertion Loss 0.10 dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Push/Pull Tabs No Breakout No Trunk No Optical Port LC STANDARDS & COMPLIANCE Protection Rating IP68 Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N820-05M-IND 价格&库存
很抱歉,暂时无法提供与“N820-05M-IND”相匹配的价格&库存,您可以联系我们找货
N820-05M-IND
  • 1+536.956321+69.59977
