1000 Eaton Boulevard
Cleveland, OH 44122
United States
10Gb Rigid Industrial Duplex Multimode 50/125
OM3 Fiber Patch Cable (LC/LC) - IP68, Aqua, 10
m (32.8 ft.)
Highlights
Protects 10Gb fiber Ethernet
applications in outdoor or harsh
environments
Resists dust and endures
immersion in 1.5 m of water up
to 60 min.
Low insertion loss of >0.10 db
ensures a strong signal through
your network
Color-coded aqua for fast, easy
OM3 identification in a crowded
rack or patch panel
MODEL NUMBER: N820-10M-IND
Applications
Connects fiber optic Ethernet equipment in industrial environments that require protection against dust
and moisture.
Connect 10G fiber Ethernet
networks in factories,
warehouses, recycling plants,
machine shops and other
environments prone to dust or
water
Provide connectivity in outdoor
environments susceptible to
rain, such as a stadium or
outdoor arena
Package Includes
Features
10G Duplex Multimode Cable Designed for Outdoor or Harsh Indoor EnvironmentsThis 32.8-foot
(10-meter) 50/125 OM3 LC/LC IP68-rated outdoor cable is ideal for connecting 10G Ethernet fiber
networks in outdoor applications and other areas where protection from harsh elements is essential, such
as factories, warehouses, recycling plants, machine shops and other dusty environments. The rigid,
durable cable and small-form-factor LC duplex connectors withstand dust, debris and moisture that could
threaten your IT infrastructure. Included dust caps are located at both ends for protection from dust and
debris when the connectors are not in use.
IP68 Rating Denotes Resistance to Dust and WaterThe fiber cable is 100% protected against dust and
able to endure immersion in 1.5 meters of water for up to 60 minutes with no damage or decline in
performance. Concentration of water moisture in fiber connectors will lead to glass damage and can
severely disrupt or halt performance of optical cables. For applications that require IP68 protection, use
the industrial cable with a N206-SB01-IND surface-mount box and an N455-BC01-IND bulkhead coupler.
If only IP44 protection against splashing water from all directions is required, pair the cable with a N206FP01-IND, N206-FP02-IND or N206-FP04-IND metal wall plate and an N455-BC01-IND bulkhead
coupler.
Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis fiber cable features an
aqua PVC jacket with LC duplex ends. The color-coding allows easy, fast OM3 identification in a crowded
rack, patch panel or workstation and helps prevent the cable from becoming inadvertently disconnected.
Specifications
OVERVIEW
UPC Code
037332252753
Technology
Multimode
1/3
N820-10M-IND 10Gb Duplex
Multimode 50/125 OM3 Fiber
Patch Cable, Aqua, 10 m
Cleveland, OH 44122
United States
Optical Mode
OM3
PHYSICAL
Cable Jacket Color
Aqua
Connector Color
Beige
Cable Jacket Material
PVC
Cable Jacket Rating
OFNR
Cable Outer Diameter (OD)
7.5 mm
Clad Diameter (microns)
50
Core Diameter (microns)
125
Number of Fibers
2
Cable Length (ft.)
32.81
Cable Length (m)
10.00
Cable Length (in.)
393.7
Cable Length (cm)
1000
Minimum Bend Radius
7.5 * 20=150mm
Fiber Cable Length
10M (32.8 ft)
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Relative Humidity
0% to 90% RH, Non-Condensing
Operating Humidity Range
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
10 Gbps
Attenuation @ 1310NM
1.5dB/km
Attenuation @ 850NM
3.5 dB/km
Insertion Loss
0.10 dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
LC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
2/3
Cleveland, OH 44122
United States
Push/Pull Tabs
No
Breakout
No
Trunk
No
Optical Port
LC
STANDARDS & COMPLIANCE
Protection Rating
IP68
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N820-10M-IND”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+646.592451+83.65400
