N820X-02M-OM4
N820X-02M-OM4
    TRIPPLITE
    光纤电缆 LC 双工 至 LC 双工 50/125 6.6'(2.0m)
N820X-02M-OM4 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 400G Multimode 50/125 OM4 Switchable Fiber Optic Cable (Duplex LC-PC M/M), LSZH, Aqua, 2 m (6.6 ft.) Highlights ● OM4-rated cable recommended for 400 Gb speeds up to 100 meters (@ 850 nm) ● Switchable connector ends allow polarity conversion without tools or re-termination ● Allows use of stacked LC adapters to increase population density ● Backward compatible with 40/100 Gb networks to facilitate future-proofing ● Aqua LSZH jacket allows fast, easy identification in a crowded switch or patch panel MODEL NUMBER: N820X-02M-OM4 Package Includes N820X-02M-OM4 400G Multimode 50/125 OM4 Switchable Fiber Optic Cable, Aqua, 2 m (6.6 ft.) 400 GbE Ethernet cable supports high bandwidths necessary for next-generation cloud services, hyperscale data centers and telecom carriers. Features 400 GbE Cable Supports Higher Bandwidths Needed for Next-Generation Data Networking As the amount of traffic in data networks grows, so does the need for next-gen devices and fiber cables to support higher bandwidths in cloud services, hyperscale data centers, telecom applications and equipment OEM companies. This multimode 50/125 OM4 cable is an ideal choice for 400G Ethernet applications up to 100 meters (328 feet) at 850 nm. It is also backward compatible with 40 Gb and 100 Gb networks, so you can future-proof your current application for an eventual upgrade to 400 Gb. Switchable LC Connectors Allow Easy Polarity Conversions The switchable LC duplex connectors on both ends of the cable let you easily switch the fiber polarity without tools or the need to re-terminate the connectors. This can allow for stacked LC adapters, eliminating the need for dual zip cords and reducing overall bulk cabling in high-density situations. Just remove the clipped piece holding the connector ends together on each side, identify the send and receive ends, and switch the polarity of those ends based on your application needs. Aqua-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OM4-rated cable has an aqua jacket to identify it as multimode in a crowded patch panel or switch and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly ventilated areas. Specifications OVERVIEW UPC Code 037332272805 Technology Multimode 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Optical Mode OM4 Mode Type Multimode PHYSICAL Cable Jacket Color Aqua Connector Color Aqua Cable Jacket Material LSZH Cable Jacket Rating OFNR Cable Outer Diameter (OD) 2 mm x 4.1 mm Clad Diameter (microns) 125.0 Core Diameter (microns) 50.0 Primary Coating Diameter (microns) 600.0 Number of Fibers 2 Cable Length (ft.) 6.56 Cable Length (m) 2.00 Cable Length (in.) 78.7 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Fiber Cable Length 2M (6.6 ft) ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Network Compatibility 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps Wavelength 1300nm; 850nm Attenuation @ 850NM 3.5 dB/km Attenuation @ 1300NM 1.5 dB/km Insertion Loss 0.20 dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC Switchable Polarity Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No Optical Port LC STANDARDS & COMPLIANCE Product Certifications UL 1666 Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N820X-02M-OM4
物料型号:N820X-02M-OM4
器件简介: - 该光纤光缆适用于400Gb速度,推荐在100米内使用(@ 850 nm)。 - 可切换连接器端允许在不需要工具或重新端接的情况下进行极性转换。 - 支持使用堆叠LC适配器以增加人口密度。 - 向后兼容40/100 Gb网络,以便于未来的升级。
引脚分配: - 连接器类型:LC DUPLEX(MALE) - 端面抛光:PC(物理接触) - 可切换极性:是
参数特性: - 光纤模式类型:OM4多模 - 光纤外套颜色:水蓝色 - 连接器颜色:水蓝色 - 光纤外套材料:LSZH(低烟无卤) - 光纤外套等级:OFNR - 光纤外径:2mmx4.1mm - 包层直径:125.0微米 - 主涂层直径:600.0微米 - 光纤数量:2 - 光纤光缆长度:2米(6.6英尺) - 最小弯曲半径:20毫米(动态);10毫米(静态) - 工作温度范围:-4°F至140°F(-20°C至60°C) - 存储温度范围:-4°F至140°F(-20°C至60°C) - 工作湿度范围:5%至85% RH,无冷凝 - 存储湿度范围:5%至85% RH,无冷凝 - 网络兼容性:10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps - 波长:1300nm:850nm - 850nm处衰减:3.5dB/km - 1300nm处衰减:1.5dB/km - 插入损耗:0.20dB
功能详解: - 400GbE以太网电缆支持下一代云服务、超大规模数据中心和电信运营商所需的高带宽。 - 可切换LC连接器允许轻松切换光纤极性,无需工具或重新端接连接器。 - 水蓝色外套有助于在拥挤的交换机或配线架中快速、容易地识别,防止意外断开。
应用信息: - 适用于400G以太网应用,支持高达100米(328英尺)的传输距离。 - 向后兼容,可为当前应用提供未来升级到400Gb的保障。
封装信息: - 产品认证:UL1666 - 产品合规性:RoHS; CE(欧洲); REACH - 产品保修期(全球):有限终身保修
N820X-02M-OM4 价格&库存
很抱歉,暂时无法提供与“N820X-02M-OM4”相匹配的价格&库存,您可以联系我们找货
N820X-02M-OM4
  • 1+247.525151+32.02116
