N820X-04M
N820X-04M
    TRIPPLITE
    光纤电缆 LC 双工 至 LC 双工 50/125 13.1'(4.0m)
N820X-04M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 400G Multimode 50/125 OM3 Switchable Fiber Optic Cable (Duplex LC-PC M/M), LSZH, Aqua, 4 m (13.1 ft.) Highlights ● OM3-rated cable recommended for 400 Gb speeds up to 100 meters (@ 850 nm) ● Switchable connector ends allow polarity conversion without tools or re-termination ● Allows use of stacked LC adapters to increase population density ● Backward compatible with 40/100 Gb networks to facilitate future-proofing ● Aqua LSZH jacket allows fast, easy identification in a crowded switch or patch panel MODEL NUMBER: N820X-04M Package Includes N820X-04M 400G Multimode 50/125 OM3 Switchable Fiber Optic Cable, Aqua, 4 m (13.1 ft.) 400 GbE Ethernet cable supports high bandwidths necessary for next-generation cloud services, hyperscale data centers and telecom carriers. Features 400 GbE Cable Supports Higher Bandwidths Needed for Next-Generation Data Networking As the amount of traffic in data networks grows, so does the need for next-gen devices and fiber cables to support higher bandwidths in cloud services, hyperscale data centers, telecom applications and equipment OEM companies. This multimode 50/125 OM3 cable is an ideal choice for 400G Ethernet applications up to 100 meters (328 feet) at 850 nm. It is also backward compatible with 40 Gb and 100 Gb networks, so you can future-proof your current application for an eventual upgrade to 400 Gb. Switchable LC Connectors Allow Easy Polarity Conversions The switchable LC duplex connectors on both ends of the cable let you easily switch the fiber polarity without tools or the need to re-terminate the connectors. This can allow for stacked LC adapters, eliminating the need for dual zip cords and reducing overall bulk cabling in high-density situations. Just remove the clipped piece holding the connector ends together on each side, identify the send and receive ends, and switch the polarity of those ends based on your application needs. Aqua-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OM3-rated cable has an aqua jacket to identify it as multimode in a crowded patch panel or switch and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly ventilated areas. Specifications OVERVIEW UPC Code 037332271617 Technology Multimode 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Optical Mode OM3 Mode Type Multimode PHYSICAL Cable Jacket Color Aqua Connector Color Beige Cable Jacket Material LSZH Cable Jacket Rating OFNR Cable Outer Diameter (OD) 2 mm x 4.1 mm Clad Diameter (microns) 125.0 Core Diameter (microns) 50.0 Primary Coating Diameter (microns) 600.0 Number of Fibers 2 Cable Length (ft.) 13.12 Cable Length (m) 4.00 Cable Length (in.) 157.5 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Fiber Cable Length 4M (13.1 ft) ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Network Compatibility 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps Wavelength 1300nm; 850nm Attenuation @ 850NM 3.5 dB/km Attenuation @ 1300NM 1.5 dB/km Insertion Loss 0.20 dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC Switchable Polarity Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No Optical Port LC STANDARDS & COMPLIANCE Product Certifications UL 1666 Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N820X-04M 价格&库存
很抱歉,暂时无法提供与“N820X-04M”相匹配的价格&库存,您可以联系我们找货
N820X-04M
  • 1+236.486911+30.59319
