1000 Eaton Boulevard
Cleveland, OH 44122
United States
400G Multimode 50/125 OM3 Switchable Fiber
Optic Cable (Duplex LC-PC M/M), LSZH, Aqua, 7
m (23 ft.)
Highlights
OM3-rated cable recommended
for 400 Gb speeds up to 100
meters (@ 850 nm)
Switchable connector ends
allow polarity conversion without
tools or re-termination
Allows use of stacked LC
adapters to increase population
density
Backward compatible with
40/100 Gb networks to facilitate
future-proofing
Aqua LSZH jacket allows fast,
easy identification in a crowded
switch or patch panel
MODEL NUMBER: N820X-07M
Package Includes
N820X-07M 400G Multimode
Optic Cable, Aqua, 7 m (23 ft.)
400 GbE Ethernet cable supports high bandwidths necessary for next-generation cloud services,
hyperscale data centers and telecom carriers.
Features
400 GbE Cable Supports Higher Bandwidths Needed for Next-Generation Data Networking
As the amount of traffic in data networks grows, so does the need for next-gen devices and fiber cables to
support higher bandwidths in cloud services, hyperscale data centers, telecom applications and
equipment OEM companies. This multimode 50/125 OM3 cable is an ideal choice for 400G Ethernet
applications up to 100 meters (328 feet) at 850 nm. It is also backward compatible with 40 Gb and 100 Gb
networks, so you can future-proof your current application for an eventual upgrade to 400 Gb.
Switchable LC Connectors Allow Easy Polarity Conversions
The switchable LC duplex connectors on both ends of the cable let you easily switch the fiber polarity
without tools or the need to re-terminate the connectors. This can allow for stacked LC adapters,
eliminating the need for dual zip cords and reducing overall bulk cabling in high-density situations. Just
remove the clipped piece holding the connector ends together on each side, identify the send and receive
ends, and switch the polarity of those ends based on your application needs.
Aqua-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OM3-rated cable has an aqua jacket to identify it as multimode in a crowded patch panel or switch
and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH)
jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly
ventilated areas.
Specifications
OVERVIEW
UPC Code
037332271709
Technology
Multimode
1/3
Cleveland, OH 44122
United States
Optical Mode
OM3
Mode Type
Multimode
PHYSICAL
Cable Jacket Color
Aqua
Connector Color
Beige
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Cable Outer Diameter (OD)
2 mm x 4.1 mm
Clad Diameter (microns)
125.0
Core Diameter (microns)
50.0
Primary Coating Diameter (microns)
600.0
Number of Fibers
2
Cable Length (ft.)
22.97
Cable Length (m)
7.00
Cable Length (in.)
275.6
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
7M (23 ft)
ENVIRONMENTAL
Operating Temperature Range
-4° to 140°F (-20° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps
Wavelength
1300nm; 850nm
Attenuation @ 850NM
3.5 dB/km
Attenuation @ 1300NM
1.5 dB/km
Insertion Loss
0.20 dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
LC DUPLEX (MALE)
Endface Polish
PC
Switchable Polarity
Yes
2/3
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
Optical Port
LC
STANDARDS & COMPLIANCE
Product Certifications
UL 1666
Product Compliance
RoHS; CE (Europe); REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N820X-07M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+295.415101+38.38995
