N821-50M-AQ-AR
N821-50M-AQ-AR
    TRIPPLITE
    光纤电缆 LC 双工 至 LC 双工 50/125 164.0'(50.0m)
N821-50M-AQ-AR 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 100G Duplex Multimode 50/125 OM4 Armored Fiber Optic Cable (LC/LC Duplex M/M), LSZH, Aqua, 50 m (164 ft.) Highlights ● OM4-rated cable recommended for 100 Gb speeds up to 50 meters (@ 850 nm) ● Flexible stainless steel tubing protects fiber and helps cable stand up to rigorous use ● Backward compatible with 10/25/40 Gb networks to facilitate future-proofing ● Aqua LSZH jacket allows fast, easy identification in a crowded switch or patch panel MODEL NUMBER: N821-50M-AQ-AR Applications Connect 100G fiber Ethernet networks in your cloud service, hyperscale data center or telecom application Package Includes 100 GbE Ethernet cable with protective steel armor supports high bandwidths necessary for cloud services, hyperscale data centers and telecom carriers. Features 100 GbE Cable Supports Higher Bandwidths Needed for Data Networking As the amount of traffic in data networks grows, so does the need for devices and fiber cables to support higher bandwidths in cloud services, hyperscale data centers, telecom applications and equipment OEM companies. This duplex multimode 50/125 OM4 cable is an ideal choice for 100G Ethernet applications up to 50 meters (164 feet) at 850 nm. It is also backward compatible with 10 Gb, 25 Gb and 40 Gb networks, so you can future-proof your current application for an eventual upgrade to 100 Gb. Armored Cable Provides Great Flexibility and Durability The N821-50M-AQ-AR can be run anywhere and does not need to be in conduit. Built-in flexible stainless steel and robust Aramid yarn protect the optical fibers more effectively than standard fiber optic cables do. The rugged armored tubing allows optical fiber to be installed in the most hazardous areas, including environments with excessive dust, oil, gas and moisture. This fiber cable provides low insertion loss and high return loss. Aqua Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OM4-rated cable has an aqua-colored jacket to identify it as multimode in a crowded patch panel or switch and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly ventilated areas. Specifications OVERVIEW UPC Code 037332264367 Technology Multimode 1/3 N821-50M-AQ-AR 100Gb Duplex Multimode 50/125 OM4 Armored Fiber Optic Cable, Aqua, 50 m (164 ft.) 1000 Eaton Boulevard Cleveland, OH 44122 United States Optical Mode OM4 Mode Type Multimode PHYSICAL Material of Construction Outer Jacket: PVC (LSZH Rating); Inner Flexible Steel Tube: SUS204 (Armored) Cable Jacket Color Aqua Connector Color Aqua; White Cable Jacket Material LSZH Cable Jacket Rating OFNR Cable Outer Diameter (OD) 3.0 mm Clad Diameter (microns) 125 Core Diameter (microns) 50 Primary Coating Diameter (microns) 550 Number of Fibers 2 Cable Length (ft.) 164 Cable Length (m) 50.00 Cable Length (in.) 1968.5 Minimum Bend Radius 30mm Shipping Dimensions (hwd / in.) 12.00 x 10.50 x 0.50 Shipping Weight (kg) 0.72 Fiber Cable Length 50M (164 ft) ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps Wavelength 1300nm; 850nm Attenuation @ 850NM 3.0 dB/km Attenuation @ 1300NM 1.0 dB/km Insertion Loss 0.20 dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No Armored Cable Yes Optical Port LC STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N821-50M-AQ-AR 价格&库存
很抱歉,暂时无法提供与“N821-50M-AQ-AR”相匹配的价格&库存,您可以联系我们找货
