1000 Eaton Boulevard
Cleveland, OH 44122
United States
100G Duplex Multimode 50/125 OM4 Armored
Fiber Optic Cable (LC/LC Duplex M/M), LSZH,
Aqua, 75 m (246 ft.)
Highlights
OM4-rated cable recommended
for 100 Gb speeds up to 75
meters (@ 850 nm)
Flexible stainless steel tubing
protects fiber and helps cable
stand up to rigorous use
Backward compatible with
10/25/40 Gb networks to
facilitate future-proofing
Aqua LSZH jacket allows fast,
easy identification in a crowded
switch or patch panel
MODEL NUMBER: N821-75M-AQ-AR
Applications
Connect 100G fiber Ethernet
networks in your cloud service,
hyperscale data center or telecom
application
Package Includes
100 GbE Ethernet cable with protective steel armor supports high bandwidths necessary for cloud
services, hyperscale data centers and telecom carriers.
Features
100 GbE Cable Supports Higher Bandwidths Needed for Data Networking
As the amount of traffic in data networks grows, so does the need for devices and fiber cables to support
higher bandwidths in cloud services, hyperscale data centers, telecom applications and equipment OEM
companies. This duplex multimode 50/125 OM4 cable is an ideal choice for 100G Ethernet applications up
to 75 meters (246 feet) at 850 nm. It is also backward compatible with 10 Gb, 25 Gb and 40 Gb networks,
so you can future-proof your current application for an eventual upgrade to 100 Gb.
Armored Cable Provides Great Flexibility and Durability
The N821-75M-AQ-AR can be run anywhere and does not need to be in conduit. Built-in flexible stainless
steel and robust Aramid yarn protect the optical fibers more effectively than standard fiber optic cables do.
The rugged armored tubing allows optical fiber to be installed in the most hazardous areas, including
environments with excessive dust, oil, gas and moisture. This fiber cable provides low insertion loss and
high return loss.
Aqua Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OM4-rated cable has an aqua-colored jacket to identify it as multimode in a crowded patch panel or
switch and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen
(LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly
ventilated areas.
Specifications
OVERVIEW
UPC Code
037332264374
Technology
Multimode
1/3
N821-75M-AQ-AR 100Gb Duplex
Fiber Optic Cable, Aqua, 75 m
(246 ft.)
Cleveland, OH 44122
United States
Optical Mode
OM4
Mode Type
Multimode
PHYSICAL
Material of Construction
Outer Jacket: PVC (LSZH Rating); Inner Flexible Steel Tube: SUS204 (Armored)
Cable Jacket Color
Aqua
Connector Color
Aqua; White
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Cable Outer Diameter (OD)
3.0 mm
Clad Diameter (microns)
125
Core Diameter (microns)
50
Primary Coating Diameter (microns)
550
Number of Fibers
2
Cable Length (ft.)
246
Cable Length (m)
75.00
Cable Length (in.)
2952.8
Minimum Bend Radius
30mm
Shipping Dimensions (hwd / in.)
12.00 x 10.50 x 0.50
Shipping Weight (kg)
1.07
Fiber Cable Length
75M (246 ft)
ENVIRONMENTAL
Operating Temperature Range
-4° to 140°F (-20° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps
Wavelength
1300nm; 850nm
Attenuation @ 850NM
3.0 dB/km
Attenuation @ 1300NM
1.0 dB/km
Insertion Loss
0.20 dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
2/3
Cleveland, OH 44122
United States
Side B - Connector 1
LC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
Armored Cable
Yes
Optical Port
LC
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N821-75M-AQ-AR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3333.899931+433.24880
- 10+2834.3985810+368.33733
- 25+2720.4238525+353.52602
