N823L-01M-MG
N823L-01M-MG
    TRIPPLITE
    光纤电缆 LC 双工 至 SN 双工 50/125 3.3'(1.0m)
N823L-01M-MG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 40/100/400G Multimode 50/125 OM4 Fiber Optic Cable (Duplex SN-PC to Duplex LC-PC M/M), LSZH, Magenta, 1 m (3.3 ft.) Highlights ● Duplex SN connector optimized for the latest 400 Gb OSFP/QSFP-DD transceivers ● Space-saving SN plug is 4x smaller than duplex LC for easier cable management ● Switchable SN connectors allow polarity conversion without tools or re-termination ● Backward compatible with 40/100 Gb networks to facilitate future-proofing ● Magenta LSZH jacket allows fast, easy identification in a crowded switch or patch panel MODEL NUMBER: N823L-01M-MG Package Includes N823L-01M-MG 40/100/400G Multimode 50/125 OM4 Fiber Cable, Magenta, 1 m (3.3 ft.) 40/100/400 GbE Ethernet cable supports high bandwidths necessary for next-gen cloud services, hyperscale data centers and telecom carriers. Features 40/100/400 GbE Cable Supports High Bandwidths for High-Density Data Networking The N823L-01M-MG is a premium multimode fiber optic cable that supports 400 Gb Ethernet speeds for transmitting data and voice signals over short distances. As the amount of traffic in data networks grows, so does the need for next-generation devices and fiber cables to support much higher bandwidths in hyperscale, edge, enterprise and colocation data center interconnect (DCI) applications where density and speed are both very important. This OM4 cable is an ideal choice for 400 Gb Ethernet applications. It is also backward compatible with 40 Gb and 100 Gb networks, so you can future-proof your current application for an eventual upgrade to 400 Gb. Compact SN Connector Designed for the Latest OSFP/QSFP-DD Transceivers One cable end features an SN connector, which is four times smaller than the standard duplex LC connector on the other end. The SN connector provides individual and independent duplex fiber support for an OSFP/QSFP-DD transceiver. The push/pull boot encourages dense vertical stacking within a crowded patch panel or switch and makes the cable easy to install or remove with just one hand. The switchable SN/PC duplex end lets you make quick polarity changes in the field without tools or the need to re-terminate the connectors. Magenta-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OM4-rated cable has a magenta jacket to identify it as multimode in a crowded patch panel or switch and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly ventilated areas. Specifications OVERVIEW UPC Code 037332274625 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Multimode Optical Mode OM4 Mode Type Multimode PHYSICAL Cable Jacket Color Magenta Connector Color Aqua; White Cable Jacket Material LSZH Cable Jacket Rating OFNR Cable Outer Diameter (OD) 1.60 mm Clad Diameter (microns) 125.0 Core Diameter (microns) 50.0 Primary Coating Diameter (microns) 245.0 Number of Fibers 2 Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Fiber Cable Length 1M (3.3 ft) ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range 14° to 140°F (-10° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps Wavelength 1300nm; 850nm Attenuation @ 850NM 3.5dB Attenuation @ 1300NM 1.5dB Insertion Loss 0.20 dB CONNECTIONS Side A - Connector 1 SN DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Switchable Polarity Yes FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No Optical Port LC; SN STANDARDS & COMPLIANCE Product Certifications UL 1651 Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N823L-01M-MG 价格&库存
很抱歉,暂时无法提供与“N823L-01M-MG”相匹配的价格&库存,您可以联系我们找货
