1000 Eaton Boulevard
Cleveland, OH 44122
United States
400G Multimode 50/125 OM4 Fiber Optic Cable
(Duplex SN-PC M/M), LSZH, Magenta, 2 m (6.6 ft.)
MODEL NUMBER: N823S-02M-MG
Highlights
Duplex SN connectors
optimized for the latest 400 Gb
OSFP/QSFP-DD transceivers
Space-saving SN plugs are 4x
smaller than standard LC for
easier cable management
Switchable connectors allow
polarity conversion without tools
or re-termination
Compact push/pull boots allow
easy installation/removal with
just one hand
Magenta LSZH jacket allows
fast identification in a crowded
switch or patch panel
Package Includes
N823S-02M-MG 400G Multimode
50/125 OM4 Fiber Cable, Magenta,
2 m (6.6 ft.)
400 GbE Ethernet cable supports high bandwidths necessary for next-gen cloud services, hyperscale data
centers and telecom carriers.
Features
400 GbE Cable Supports High Bandwidths for High-Density Data Networking
The N823S-02M-MG is a premium multimode fiber optic cable that supports 400 Gb Ethernet speeds for
transmitting data and voice signals over short distances. As the amount of traffic in data networks grows,
so does the need for next-generation devices and fiber cables to support much higher bandwidths in
hyperscale, edge, enterprise and colocation data center interconnect (DCI) applications where density and
speed are both very important.
Compact SN Connectors Designed for the Latest OSFP/QSFP-DD Transceivers
This 400 Gb cable features duplex SN connectors on both ends. SN connectors are four times smaller
than standard LC connectors and provide individual and independent duplex fiber support for
OSFP/QSFP-DD transceivers. Push/pull boots encourage dense vertical stacking within a crowded patch
panel or switch and make the cable easy to install or remove with just one hand. The switchable SN/PC
ends let you make quick polarity changes in the field without tools or the need to re-terminate the
connectors.
Magenta-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OM4-rated cable has a magenta jacket to identify it as multimode in a crowded patch panel or switch
and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH)
jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly
ventilated areas.
Specifications
OVERVIEW
UPC Code
037332274557
Technology
Multimode
Optical Mode
OM4
1/3
Cleveland, OH 44122
United States
Mode Type
Multimode
PHYSICAL
Cable Jacket Color
Magenta
Connector Color
Aqua; White
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Cable Outer Diameter (OD)
1.60 mm
Clad Diameter (microns)
125.0
Core Diameter (microns)
50.0
Primary Coating Diameter (microns)
245.0
Number of Fibers
2
Cable Length (ft.)
6.6
Cable Length (m)
2.01
Cable Length (in.)
78.7
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
2M (6.6 ft)
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
400 Gbps
Wavelength
1300nm; 850nm
Attenuation @ 850NM
3.5dB
Attenuation @ 1300NM
1.5dB
Insertion Loss
< 0.20 dB
CONNECTIONS
Side A - Connector 1
SN DUPLEX (MALE)
Side B - Connector 1
SN DUPLEX (MALE)
Endface Polish
PC
Switchable Polarity
Yes
2/3
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
Optical Port
SN
STANDARDS & COMPLIANCE
Product Certifications
UL 1651
Product Compliance
RoHS; CE (Europe); REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N823S-02M-MG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1835.007351+238.54502
