1000 Eaton Boulevard
Cleveland, OH 44122
United States
40/100/400G Multimode 50/125 OM3 Fiber Optic
Cable (12F MTP/MPO-PC F/F), LSZH, Aqua, 1 m
(3.3 ft.)
Highlights
OM3-rated cable recommended
for 400 Gb speeds up to 100
meters (@ 1300 nm)
Backward compatible with
10/25/40/100 Gb networks to
facilitate future-proofing
Aqua LSZH jacket allows fast,
easy identification in a crowded
switch or patch panel
MODEL NUMBER: N844B-01M-12-P
Package Includes
N844B-01M-12-P 40/100/400G
Cable, Aqua, 1 m (3.3 ft.)
40/100/400 GbE Ethernet cable extends high-density connections between network components in
enterprise applications in wiring closets, telecom rooms and data centers.
Features
40/100/400 GbE Cable Supports Higher Bandwidths for High-Density Data Networking
The N844B-01M-12-P is a premium multimode fiber optic cable that supports 400 Gb Ethernet speeds for
transmitting data and voice signals over short distances. It is designed to support higher bandwidths for
high-density patching between data center MDFs and IDFs in enterprise installations. This multimode
50/125 OM3 cable is an ideal choice for 100 Gb Ethernet applications up to 100 meters (328 feet) at 1300
nm. It is also backward compatible with 10 Gb and 25 Gb networks, so you can future-proof your current
application for an eventual upgrade to 100 Gb or 400 Gb.
Aqua-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OM3-rated cable has an aqua jacket to identify it as multimode in a crowded patch panel or switch
and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH)
jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly
ventilated areas. The connectors’ slim boot and aqua housing allow easy one-handed installation and
removal of the cable.
Specifications
OVERVIEW
UPC Code
037332272911
Technology
Multimode
Optical Mode
OM3
Mode Type
Multimode
PHYSICAL
1/3
Cleveland, OH 44122
United States
Cable Jacket Color
Aqua
Connector Color
Black
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Cable Outer Diameter (OD)
3.0 mm
Clad Diameter (microns)
125.0
Core Diameter (microns)
50.0
Primary Coating Diameter (microns)
245.0
Number of Fibers
12
Cable Length (ft.)
3.28
Cable Length (m)
1.00
Cable Length (in.)
39.4
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
1M (3.3 ft)
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
40 Gbps; 100 Gbps; 400 Gbps
Wavelength
1300nm; 850nm
Attenuation @ 850NM
3.5 dB/km
Attenuation @ 1300NM
1.5 dB/km
Insertion Loss
0.35 dB
CONNECTIONS
Side A - Connector 1
12-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
Endface Polish
PC
Polarity
Type B (cross)
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
2/3
Cleveland, OH 44122
United States
Trunk
No
Optical Port
MPO/MTP
STANDARDS & COMPLIANCE
Product Certifications
UL 1666
Product Compliance
RoHS; CE (Europe); REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N844B-01M-12-P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1191.541441+154.15769
- 10+1012.8610710+131.04062
- 25+949.5130825+122.84487
- 50+943.3378150+122.04593
