1000 Eaton Boulevard
Cleveland, OH 44122
United States
40/100/400G Multimode 50/125 OM4 Breakout
Fiber Optic Cable (12F MTP/MPO-PC to 4x
Duplex SN-PC F/M), LSZH, Magenta, 3 m (9.8 ft.)
Highlights
Duplex SN connector optimized
for the latest 400 Gb
OSFP/QSFP-DD transceivers
Space-saving SN plug is 4x
smaller than duplex LC for
easier cable management
Switchable SN connectors allow
polarity conversion without tools
or re-termination
Backward compatible with
40/100 Gb networks to facilitate
future-proofing
Magenta LSZH jacket allows
fast, easy identification in a
crowded switch or patch panel
MODEL NUMBER: N845-03M-4S-MG
Package Includes
N845-03M-4S-MG 40/100/400G
Multimode 50/125 OM4 Fiber
Cable, Magenta, 3 m (9.8 ft.)
40/100/400 GbE Ethernet cable supports high bandwidths necessary for next-gen cloud services,
hyperscale data centers and telecom carriers.
Features
40/100/400 GbE Cable Supports High Bandwidths for High-Density Data Networking
The N845-03M-4S-MG is a premium multimode fiber optic cable that supports 400 Gb Ethernet speeds for
transmitting data and voice signals over short distances. As the amount of traffic in data networks grows,
so does the need for next-generation devices and fiber cables to support much higher bandwidths in cloud
services, hyperscale data centers, telecom applications and equipment OEM companies. This OM4
breakout cable is an ideal choice for 400 Gb Ethernet applications. It is also backward compatible with 40
Gb and 100 Gb networks, so you can future-proof your current application for an eventual upgrade to 400
Gb.
Compact SN Connector Designed for the Latest OSFP/QSFP-DD Transceivers
One cable end features SN connectors, which are four times smaller than a standard duplex LC connector
and provide individual and independent duplex fiber breakout at a quad-style OSFP/QSFP-DD
transceiver. The push/pull boots encourage dense vertical stacking within a crowded patch panel or switch
and make the cable easy to install or remove with just one hand. Switchable SN/PC duplex ends let you
make quick polarity changes in the field without tools or the need to re-terminate the connectors.
Magenta-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OM4-rated cable has a magenta jacket to identify it as multimode in a crowded patch panel or switch
and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH)
jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly
ventilated areas.
Specifications
OVERVIEW
UPC Code
037332274663
1/3
Cleveland, OH 44122
United States
Technology
Multimode
Optical Mode
OM4
Mode Type
Multimode
PHYSICAL
Cable Jacket Color
Magenta
Connector Color
Aqua; Black; White
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Cable Outer Diameter (OD)
3.0 mm
Clad Diameter (microns)
125.0
Core Diameter (microns)
50.0
Primary Coating Diameter (microns)
245.0
Number of Fibers
12
Cable Length (ft.)
9.8
Cable Length (m)
2.99
Cable Length (in.)
118.1
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
3M (9.8 ft)
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Network Compatibility
40 Gbps; 100 Gbps; 400 Gbps
Wavelength
1300nm; 850nm
Attenuation @ 850NM
3.5dB
Attenuation @ 1300NM
1.5dB
Insertion Loss
MTP/MPO: < 0.35 dB; SN: < 0.20 dB
CONNECTIONS
Side A - Connector 1
12-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
(4) SN DUPLEX (MALE)
Endface Polish
PC
2/3
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
Yes
Optical Port
MPO/MTP; SN
STANDARDS & COMPLIANCE
Product Certifications
UL 1651
Product Compliance
RoHS; CE (Europe); REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N845-03M-4S-MG”相匹配的价格&库存,您可以联系我们找货
