N845B-05M-12-MG
N845B-05M-12-MG
    TRIPPLITE
    光纤电缆 MTP 至 MTP 50/125 16.4'(5.0m)
N845B-05M-12-MG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 100G Multimode 50/125 OM4 Fiber Optic Cable (12F MTP/MPO-PC F/F), LSZH, Magenta, 5 m (16.4 ft.) Highlights ● OM4-rated cable recommended for 100 Gb speeds up to 100 meters (@ 1300 nm) ● Backward compatible with 10/25/40 Gb networks to facilitate future-proofing ● Magenta LSZH jacket allows easy ID in a crowded switch or patch panel MODEL NUMBER: N845B-05M-12-MG Package Includes N845B-05M-12-MG 100G Multimode 50/125 OM4 Fiber Optic Cable, Magenta, 5 m (16.4 ft.) 40/100 GbE Ethernet cable extends high-density connections between network components in enterprise applications in wiring closets, telecom rooms and data centers. Features 40/100 GbE Cable Supports Higher Bandwidths Needed for High-Density Data Networking As the amount of traffic in data networks grows, so does the need for devices and fiber cables to support higher bandwidths for high-density patching between data center MDFs and IDFs in enterprise installations. This multimode 50/125 OM4 cable is an ideal choice for 100G Ethernet applications up to 100 meters (328 feet) at 1300 nm. It is also backward compatible with 10 Gb and 25 Gb networks, so you can future-proof your current application for an eventual upgrade to 400 Gb. Magenta Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OM4-rated cable has a magenta jacket to identify it as multimode in a crowded patch panel or switch and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly ventilated areas. The connectors’ slim boots allow easy one-handed installation and removal of the cable. Specifications OVERVIEW UPC Code 037332272263 Technology Fiber; Multimode Optical Mode OM4 PHYSICAL Cable Jacket Color Magenta Connector Color Magenta; Black 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125.0 Core Diameter (microns) 50.0 Primary Coating Diameter (microns) 245.0 Number of Fibers 12 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.85 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Fiber Cable Length 5M (16.4 ft) ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Relative Humidity 5% to 85% RH, Non-Condensing COMMUNICATIONS Network Compatibility 10 Gbps; 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 850NM 3.5 dB/km Attenuation @ 1300NM 1.5 dB/km Insertion Loss 0.35 dB CONNECTIONS Side A - Connector 1 12-STRAND MTP/MPO (FEMALE) Side B - Connector 1 12-STRAND MTP/MPO (FEMALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs Yes STANDARDS & COMPLIANCE Product Certifications UL 1666 Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N845B-05M-12-MG 价格&库存
很抱歉,暂时无法提供与“N845B-05M-12-MG”相匹配的价格&库存,您可以联系我们找货
