N845X-02M-8L-MG
N845X-02M-8L-MG
    TRIPPLITE
    光纤电缆 MTP 至 LC 双工(4) 50/125 6.6'(2.0m)
N845X-02M-8L-MG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 40/100G Multimode 50/125 OM4 Fiber Optic Cable (12F MTP/MPO-PC to 4x Duplex LC/PC F/M), LSZH, Magenta, 2 m (6.6 ft.) Highlights ● OM4-rated cable recommended for 100 Gb speeds up to 100 meters (@ 850 nm) ● Switchable LC connectors allow polarity conversion without tools or re-termination ● Backward compatible with 10/25/40 Gb networks to facilitate future-proofing ● Magenta LSZH jacket allows easy ID in a crowded switch or patch panel MODEL NUMBER: N845X-02M-8L-MG Package Includes N845X-02M-8L-MG 40/100G Multimode 50/125 OM4 Fiber Optic Cable, Magenta, 2 m (6.6 ft.) 40/100 GbE Ethernet cable extends high-density network connections in enterprise applications in data centers, telecom rooms and wiring closets. Features 40/100 GbE Cable Supports Higher Bandwidths Needed for High-Density Data Networking As the amount of traffic in data networks grows, so does the need for devices and fiber cables to support higher bandwidths for high-density patching between data center MDFs and IDFs in enterprise installations. This multimode 50/125 OM4 fan-out cable is an ideal choice for 100 Gb Ethernet applications up to 100 meters (328 feet) at 850 nm. It is also backward compatible with 10 Gb and 25 Gb networks, so you can future-proof your current application for an eventual upgrade to 400 Gb. Switchable LC Connectors Allow Easy Polarity Conversions The switchable LC/PC duplex ends let you easily switch the fiber polarity without tools or the need to reterminate the connectors. Use the detachable clip to keep the connectors in place while in use. Magenta Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OM4-rated cable has a magenta jacket to identify it as multimode in a crowded patch panel or switch and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly ventilated areas. The connectors’ slim boots allow easy one-handed installation and removal of the cable. Specifications OVERVIEW UPC Code 037332272324 Technology Fiber; Multimode Optical Mode OM4 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Cable Jacket Color Magenta Connector Color Aqua; Magenta; Black Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125.0 Core Diameter (microns) 50.0 Primary Coating Diameter (microns) 245.0 Number of Fibers 8 Cable Length (ft.) 6.6 Cable Length (m) 2.01 Cable Length (in.) 78.4 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Fiber Cable Length 2M (6.6 ft) ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Relative Humidity 5% to 85% RH, Non-Condensing COMMUNICATIONS Network Compatibility 10 Gbps; 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 850NM 3.5 dB/km Attenuation @ 1300NM 1.5 dB/km Insertion Loss 0.35 dB CONNECTIONS Side A - Connector 1 12-STRAND MTP/MPO (FEMALE) Side B - Connector 1 (4) LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs Yes Breakout Yes Trunk Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications UL 1666 Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N845X-02M-8L-MG
1. 物料型号:N845X-02M-8L-MG 2. 器件简介:40/100G多模50/125 OM4光纤电缆,适用于数据中心、电信室和布线间的高密度网络连接。 3. 引脚分配:侧A - 连接器1为12芯MTP/MPO(母头),侧B - 连接器1为4个LC双工(公头)。 4. 参数特性: - 技术:多模光纤 - 光模式:OM4 - 光纤数量:8根 - 电缆长度:2米(6.6英尺) - 操作温度范围:-4°至140°F(-20°至60°C) - 衰减@850NM:3.5 dB/km - 插入损耗:0.35 dB 5. 功能详解: - 支持40/100 GbE以太网电缆,适用于高带宽需求的高密度数据网络。 - 可切换的LC连接器允许在不需要工具或重新端接的情况下轻松转换光纤极性。 - 与10/25/40 Gb网络向后兼容,为将来升级到400 Gb提供保障。 - 紫红色LSZH外皮有助于在拥挤的交换机或配线架中容易识别。 6. 应用信息:推荐用于100 Gb速度下100米(@ 850 nm)的OM4级别电缆。 7. 封装信息:紫红色LSZH外皮,连接器颜色为水绿色、紫红色、黑色。
N845X-02M-8L-MG 价格&库存
很抱歉,暂时无法提供与“N845X-02M-8L-MG”相匹配的价格&库存,您可以联系我们找货
